brake rotor scraping sound
can't find much info on similar problem so here it goes, lately i've been starting to hear what i think are my rotors when i press the brakes, i hear a scraping/rubbing sound, it is louder at first when i wash the car and the rotors get rusty right away (i don't know if anybody every noticed that on their car but that's what happens to mine every car wash) goes away after a while but its still a rubbing sound, its not squealing i fixed that after replacing my front pads 10k (km not miles ago) rotors look and feel alright, i don't think they're warped, i do get a lot of brake dust, is it possible there's loose brake dust stuck between the brake pad and the rotor and it stays there and that's what making that sound, or is it the OEM brake pads that just get noisy after a couple of kms?
sounds like your pads are gone. the squealing may be the 'crickets' on the brake pads - it's the small metal tabs that contact the rotor when your pad is almost gone.
The OEM pads suck so when you do a brake job, do an upgrade. Hawk pads seem to be the way to go. I grabbed some ceramic/low dust pads from the Autozone b/c I couldn't wait on shipping for the Hawk pads. Just the reduced dust makes it worth the extra money.
hmm i better take a look at the pads from i did hear that they go pretty fast but 10 kilos? that cricket sound would be constant if the pads were worn wouldn't it? i only hear rubbing when i hit the brakes
This is the 1st place to look-- if it's not here, write back and we'll explore other options. Good Luck!
thanks guys, i'll take a look at the pads next weekend, i hate the brakedust the OEM pads create, but i'd rather have dust then squealing, can i use the OEM anti squeal shims on aftermarket pads? i guess i'd go with the hawks cuz i see most guys use these on our cars, is there a specific type of the hawks i should get or is there only one kind the ceramic kind for the G?
does anybody experience rotors rusting after a car wash? i get that everytime i googled this problem and ended up on a honda forum where a guy says the dealer tech told him its normal to have that sound if u have rusty rotors
Yes I get a slight rust coating when I wash. The rotors are IRON after all. And you can go with low dust aftermarket pads but you WILL lose brake performance (at least cold 60-0 performance with I consider important). OEM pads dust like crazy but it's what you have to do to get the world class brake performance.
The squeak is probably the pad "ears" vibrating back and forth on their pad holders. These areas get real dirty with the oem pads. I recommend cleaning the calipers very well and applying a light coating of high temp grease to the pad ears and where the ride on (BUT NOT ON THE PAD SURFACE OF COURSE !! lol)
so these hawks aren't better for stopping power then? i thought they were better overall, i'll take the brakes apart on saturday and see what's goin on in there
Probably not better for cold intial 60-0 stopping power. They might have better performance at high temps vs stock. Depends on what pads you bought and your definition of "overall"
well i decided to check the brakes today, took the pads out and cleaned them along with the calipers, clips and what have you not, the rubbing sound is there even when i turn the wheel when its lifted u hear it rub, the cleaning did help a little, so its either the rotors that need to be replaced or the OEM pads go noisy after a while, good thing the pads don't look worn at all for 10kilos so i'm happy about that
I think it is the corrosion build up on the top of the rotors and it scraps the inner sides of the caliper, I had the same problem. You can either get new rotors that have a better zine coating on them to stop from corrosion or just get a brake service done and the shop will clean the caliper.
i have a 03 g35 sedan 5/AT just replaced rotors and pads all around myself
wagner lazer edge 100% ceramic
atlas aftermarket rotors
stops on a dime from 60-0 but grinding and squeal noise wen u first get in and drive but the grind and squeal goes away after u hit the brake 2-3 times its weird
i always get my breaks checked on the next scedualed oil change to make sure i didnt make a boo boo and i always get the thumbs up
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
