dealer settings... wth?
Old Jun 21, 2004 | 04:05 AM
Msedanman's Avatar
O.F. Administrator
Re: dealer settings... wth?
Our rides are shipped with high pressures to help guard against flat-spotting and to help with clearance when offloading truck ramps etc. Hahaha, some have complained that theirs have had 50+ psi when they check pressures because the dealer forgot.
When I had my Sedan, I ran about 35 psi, but the manual calls for 30, which I thought was too soft. 35 will get you a little better gas mileage, and slightly tighter in the corners.
Don't go any higher tho -- the contact patch will be too small.
Enjoy your Sedan. [img]/w3timages/icons/smile.gif[/img]
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jun 21, 2004 | 08:17 AM
bsgoren's Avatar
Are you checking the tire pressure before running the car when the tires are cold? After running the car, I've checked my tire pressure and they're at about 39-41 because they're hot and the air has expanded. When cold, I like to keep the tire pressure at about 34-35. BTW - I don't understand why Infiniti had to cheap out in the G35 Navi system and not add the individual tire pressure readings (under the Navi's 'Info' display) just like in the FX35 (which shows what each individual tire's pressure in real time). I was very disappointed when I found out that the G35 just has 1 dashboard warning light to indicate that '1 or more of the tires' air pressure is low'...there's 4 of them, and which one would that be??????? A little vague.
2004.5 G35-S 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels, Alum Pedals, Dark Tint, Z Tube, K&N Filter
Old Jun 21, 2004 | 02:50 PM
KingoftheRoad1's Avatar
This is due to the sloppy dealer service. Mine was delivered at around 40 also. The ride was rough on the way home from the dealer. When I test drove the car, the ride was not so rough. I adjusted the pressure when I got home.
This should be done at the dealer's as part the check list when delivering the car. Evidently, quite a few of them don't do it. I called it sloppy and they want us to grade them excellent in the Infiniti survey!!! Heck, mine was deliver with dirty rims and just plain lousy clean up as a whole and I told the salesman also. His answer was that their regular guy was not there on that day. That did not do any good for me.
2004 G35X
Old Jun 21, 2004 | 03:55 PM
jstwong's Avatar
Interesting that you brought this up as I just checked mine recently [just got my car 3 weeks ago], and the pressure was up at 36 psi. I brought mine down to 32 psi as well.
Old Jun 21, 2004 | 04:38 PM
Msedanman's Avatar
O.F. Administrator
Bsgoren is correct. Make sure that whatever you set your pressures at that you do so when the tires are cold. I find that first thing in the morning is good b4 running the car at all.
After running the car the pressures will rise 5 psi or more.
jeffbdye
Jun 1, 2018 03:51 PM
f22raptor
Mar 18, 2016 08:50 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Gabe83714
Oct 6, 2015 06:40 AM
