Help!!! License plate screws stuck!!!
Old Jun 21, 2004 | 07:15 PM
Will_blueprint's Avatar
I have tried everything to get these things off. I had a temp plate on there now need to put the real plate on. I have tried drilling, WD40, screwdriver, even a crobar and nothing. It lets me back the screws out to a certain point they they just go into a dead spin cant move foward or back. Now I really want to get them off because I cracked up the plastic cover and bent the chrome surround. Any Suggestions.
Old Jun 21, 2004 | 07:30 PM
darylnj's Avatar
Re: Help!!! License plate screws stuck!!!
don't really understand your problem,but here goes.grab the head with a plier or vise grip and pull as you turn.if that doesn't work you will have to cut the screw heads off.use a hacksaw blade or die grinder,{dremel} they are threaded clips so if you get the screw heads off you will be able to wiggle them out of the bumper.good luck be patient
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
