How much of a drop does this sedan have?
Old Feb 21, 2009 | 04:17 AM
4drmadness's Avatar
Hey guys i really like the look of this sedan. I wanted to know how many inches he would be dropped on? like an estimate. I know he has 19's on. lemme know.
Attached Thumbnails How much of a drop does this sedan have?-3n93k33o6zzzzzzzzz92kc7598c4aa34a1fb0.jpg
Old Feb 21, 2009 | 10:47 AM
Swivel's Avatar
Moderator
Hard to tell, is this a member's car? Looks lower than Z-springs, for sure, which is an inch.
Old Feb 21, 2009 | 11:41 AM
Joe_Camel's Avatar
I agree it's kind of hard to tell, but I'd estimate about 1.5 inches. My car has Eibach pro-kit springs and there's about a 2-finger gap front and rear, which I believe is a 1.1-1.2 inch drop.
Old Feb 21, 2009 | 06:23 PM
AARONHL's Avatar
1.75", maybe just shy of 2"
Old Feb 21, 2009 | 06:52 PM
4drmadness's Avatar
Do you think this will be an upgrade from 350z springs that i have on. I hate the wheel gap, and wanna get really low springs, but not slammed tho.
Old Feb 21, 2009 | 07:23 PM
Tollboothwilley's Avatar
Get the H&R springs then. they drop the sedan a perfect amount IMO.
I dont know what the springs rates are though and since you have the 350z shocks it might wear them out faster.
Old Feb 21, 2009 | 07:28 PM
AARONHL's Avatar
OEM 350z springs will not lower a G sedan very much, so there are plenty of other springs that will give you a drop that you are looking for. You just have to decide what shocks you want to use.
Old Feb 21, 2009 | 07:57 PM
Jeff92se's Avatar
Red Card Crew
Gap also depends on what tire size that guy used.
Old Feb 21, 2009 | 08:09 PM
4drmadness's Avatar
Im gona use the 350z shocks
Old Feb 21, 2009 | 08:43 PM
AARONHL's Avatar
With progressive springs you might want to upgrade to a better aftermarket shock. I have the G sedan sport suspension so I can use linear shocks (not as stiff as progressive). I have Hotchkis 350z springs (linear) and my sedan is about 1.75 inches lower...
Old Feb 21, 2009 | 08:47 PM
4drmadness's Avatar
hmm i see. yea i might have to get some better shocks then
Old Feb 21, 2009 | 09:01 PM
AARONHL's Avatar
Progressive shocks will allow you to lower the car more, so you will need shocks that can withstand them. Don't forget a camber kit!!!!
Old Feb 22, 2009 | 12:37 AM
If you are gonna lower it with just springs, you will want to use 350z springs to pair up with the 350z shocks you are using. Take a look at the 350z Tein S-tech. They will lower the sedan an additional 1" and you will have the advantage of keeping shock dampening to a more even rate.
Old Feb 22, 2009 | 01:21 AM
4drmadness's Avatar
Now thts a better solution. This way i get the perfect drop, and dont have to buy new shocks as well. so the z s techs will give like 2 inches?
Old Feb 22, 2009 | 01:34 AM
dahkyne's Avatar
dropped 2" on eibach pro-kit + tokico d-spec for 350Z... looks like you forgot what i told you about Z suspension when you picked up my y-pipe, huh?
