215 65 -17 Will these fit my 03 stock sedan?
Old Feb 22, 2009 | 03:27 PM
puckinshat's Avatar
I just picked up my first G, 03 Sedan 6-spd, and I NEED winter tires here in Minnesota. I have found a sick deal on some 215 65 -17 but I am afraid they are too big for my stock sedan. Can someone please enlighten me to if they think they will fit? Stock is 215/55/r17; I am unsure how much the aspect ratio will effect the overall diameter.
Thanks guys!
Old Feb 22, 2009 | 04:30 PM
maciejk's Avatar
http://www.miata.net/garage/tirecalc.html
Old Feb 22, 2009 | 04:32 PM
Mustang5L5's Avatar
The stock tire size is 26.3" in diamter.
These tires would be 28.0" in diameter. It's almost 2" larger in diamter. They will be pretty larger. I wouldn't run them
Old Feb 22, 2009 | 07:19 PM
RADIOGUY21's Avatar
they should fit, but 65 is too much sidewall. Your speedometer is going to be off alittle.
Old Feb 22, 2009 | 07:22 PM
BuckeyeInMI's Avatar
Gotta agree with Mustang, those are just too big. You really shouldn't go more than 3% difference in wheel diameter (the VDC doesn't like it). Those tires are around 6.5% larger in diameter than stock. So for the stock 17x7.5's, that pretty much leaves you with these sizes, more or less.
225/50-17 25.9 (1.5% smaller diam.)
215/55-17 26.3 (stock)
225/55-17 26.7 (1.5% larger diam.)
235/50-17 26.3-26.7 (yes, some tires are different for this size)
215/60-17 27.2 (3.4% larger, pushing it a bit)
And when I say the VDC doesn't like it, I mean it will kick on more often, even if conditions are ideal. Just taking a mildly agressive turn can cause the system to think there's too much wheel slippage. I may be wrong on this last part, but I've read somewhere about this, and a mechanic mentioned it to me when I got my 225/55-17's. Plus you've got the whole speedo/odo problem. That 1.5% for my tires translates to a 3% difference in circumference. Your 215/65-17's would be about 13% different.
EnCr1pt3d
Jul 8, 2019 02:48 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
teamghost
Jul 28, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
