turbo or supercharger?
Old Jun 22, 2004 | 10:47 PM
Jobes's Avatar
i have a 2004 sedan auto and was wondering if i should get a turbo charger or a supercharger. i heard that turbochargers sound weird on automatics. let me know. thanks
Old Jun 22, 2004 | 11:41 PM
GodZilla's Avatar
Re: turbo or supercharger?
Myself I'm going supercharged with probably cams.
I think Turbo charging takes a bit more than just slaping turbos on..
Just my 2 cents.
Old Jun 24, 2004 | 01:10 PM
Typhoon's Avatar
Sound weird? I am not sure the spooling sound of a auto turbo is different than a manual. Any case, auto or manual - the sound of a turbo is AWESOME!!!!!! Man, I miss my Turbo AWD Typhoon and those 5.1 0-60 runs!!!
03.5 G35S 5AT - Desert Platinum/Graphite/350Z Tube/Clear corners/HG kit/20% Tint
Old Jun 24, 2004 | 01:19 PM
Typhoon's Avatar
Godzilla: I agree, going Turbo is definitely more complex than S/C. But, there is much more power potential.
Jobes: If your budget is limited, then S/C is the way to go now. I will wait until those turbo kits are cheaper or Infiniti puts one on the G. That would be so sweeet!!!!!
Old Jun 24, 2004 | 01:34 PM
cooIie's Avatar
Turbo should sound the same on both auto and manual. As stated above, there is much more power potential with the turbo...It just depends on what your goals are.
97 Supra Single Turbo
Old Jun 24, 2004 | 01:38 PM
RSPDiver's Avatar
One point to putting the Turbo on an AT is that you can power brake and launch at full boost. Not sure how successfuly you can do that with a supercharger. Depends on the stall speed of the G's AT, I guess.
_________________________________________
Me failed English? That's unpossible!
Old Jun 24, 2004 | 05:20 PM
Gmaster's Avatar
There is an 11 seconds G35 with Vortech supercharger (9psi) and running on STOCK internals. For me its more then enough. If you goal is less then 11s then turbo will be more efficient with upgraded internals, transmission and drive shaft which would lead to extremely expensive project.
'04 G35/5AT sedan Silver/Black
DYNO: 209.2whp@209.4wtq (bone stock)
Old Jun 24, 2004 | 11:26 PM
zimbo's Avatar
No way.
--Steve
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
ncg35guy
Sep 24, 2015 04:53 PM
