What oil are you using now that Mobil one is still in shortage?
Old Mar 12, 2009 | 03:26 PM
  #46
mingus2112's Avatar
Originally Posted by whtteg
The myth that is commonly told is that using synthetic in a high mileage engine will cause oil leaks. This is not really true, Synthetic has more detergents in it so it cleans better than conventional oil. That being said if you have seals or gaskets that are worn and there is gunk built up on them keeping them from leaking than yes the synthetic could cause them to leak. However with only 57K on your G I would absolutely switch. If you go with Amsoil there is a engine flush that you can just add to your old oil and let the motor run for 15-20 mins, then drain and fill with Amsoil, you do however replace the old filter before the flush and then install another new filter after. You can use a cheap Fram filter, they instruct you to change the filter so that you are not disolving the junk in the filter and spreading it through the motor. After draining the old oil and flush you then can install a Amsoil filter. I would say that the only reason do use the flush would be if you have been visiting oil change places and not changing the oil yourself with quality oil and filters.
Thanks for the info. I'll talk to my mechanic. I bought my Maxima with high mileage on it already. I think it was safer to assume that there could be leaks already there and not to "rock the boat" than to switch and risk possible repairs. It lasted me a good 120,000 more miles.
So the '04 G35x comes with regular oil from the factory. . .NOT synthetic?
-James
Old Mar 12, 2009 | 04:08 PM
  #47
LaConic2's Avatar
Originally Posted by barrios35
Need to change the oil. Mobil one oil is still hard to find, or ridiculously priced. So what are you guys using instead?
i didnt know there was a shortage either, but from the OPs post
hard to find or overpriced, might just be a "shortage in his pockets" LOL
jk man
i use mobil 3000/5000 plus FRAM filter, but i change oil every 2500-3k...
ill have to look into royal purple, and the NAPA GOLD filters..might do a better job.
Old Mar 12, 2009 | 04:16 PM
  #48
Jeff92se's Avatar
Red Card Crew
FYI. If you are na and change your oil every 3-5k, you could use the cheapest API certified oil in your recommended viscosity range and not have to worry about anything.
Old Mar 12, 2009 | 10:50 PM
  #49
Infiniti Chica's Avatar
Originally Posted by canucklehead
mobil 1 5W30.
I've always found it humorous how dealers push $ynthetic oil$ when the Infiniti owner's manual clearly states that synthetic oils are not to be used in our engines. at least my '04 manual says that...
Been using Mobil1 now for 40K miles. Change the filter every 4-5 K and the oil every 8-10K. My driving is normal.
My 04 manual does not say that, it only recommends that I use dyno... curious.
I've been wondering about the new Castrol Edge tho, which touts 8X more wear protection than Mobil 1 (but it's $36 per 5 quarts container). I haven't reviewed the literature to be sure it's not another marketing ploy. Anyone used it?
Old Mar 13, 2009 | 01:22 AM
  #50
mhn's Avatar
mhn
142k miles, still using synpower every 5k miles
Old Mar 13, 2009 | 01:40 AM
  #51
Jeff92se's Avatar
Red Card Crew
I've been curious too. I'd wait for the bobistheoilguy forums to comment on it. They are usually spot on accurate about their opinion on oils.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
