What Would You Guys Do?
Old Mar 18, 2009 | 05:12 PM
Wannabe6MT's Avatar
-MN G Crew-
As some of you may know, im driving to California this summer (from Minnesota) and am potentialy taking 3 others with me (4 total in my 05 G sedan).
I am concerned that with 4 people+personal stuff, that the backend will be sitting very low. I am on Z springs up front and coupe springs in the back with 19" Coupe wheels.
Has anyone hauled 4 people and luggage in a lowered sedan?
We are going to take a test run to wisconsin once we all get back from spring break, and if it is bouncy and crap, i might swap out my springs for normal rate sport sedan springs... i dont want to be dragging my rear end around.
Anyone else do this/have problems with it? Dont really want to sacrifice looks, but also dont want my car to be tearing up my tires/rubbing my exhaust every time i go over a bump.
Old Mar 18, 2009 | 06:20 PM
ttrank's Avatar
Grocery getter
I have ~150-200lbs of stereo in my trunk and have had luggage + 2 people in the back seat a few times. No issues here (plus my car slightly tucks with no one in the back).
Old Mar 18, 2009 | 07:15 PM
Wannabe6MT's Avatar
-MN G Crew-
Arent you running coilovers though? It almost seems like there is more give with these coupe springs and sedan sport shocks.
Old Mar 18, 2009 | 07:27 PM
cremaster's Avatar
how much of a drop did your coupe and z springs give you?
why don't you roll the rears just to be safe.
Old Mar 18, 2009 | 07:30 PM
Trbulnt's Avatar
Off topic but....Where in wisconsin you coming to? Depending on when and where you are going we may be having a local nissan/infiniti meet. You can P.M. me if you want.
Old Mar 18, 2009 | 07:31 PM
ttrank's Avatar
Grocery getter
For a RWD sedan:
Coupe = ~0.5"
Z = ~1"
Old Mar 18, 2009 | 07:37 PM
cremaster's Avatar
Originally Posted by ttrank
For a RWD sedan:
Coupe = ~0.5"
Z = ~1"
w/ those specs, i think janik should be good.
Old Mar 18, 2009 | 07:57 PM
OCG35's Avatar
a 1" drop isnt enough to be worried about.
Old Mar 18, 2009 | 08:16 PM
CandlestickPark's Avatar
ill Sedan
You'll be fine Janik. I've taken drives from SoCal to NorCal a few times in my G with my wife, the baby and a trunk and back seat full of luggage. Back was sitting lower but not low enough to cause any issues. I was on Eibach Pro Kit springs during these trips. If your fenders are rolled you should be good to go.
Old Mar 18, 2009 | 08:55 PM
Wannabe6MT's Avatar
-MN G Crew-
Well maybe ill just have to roll them a bit more to be sure. Dont want to screw up my new Falkens..
Old Mar 18, 2009 | 09:15 PM
ill Sedan
^I was OK and I didn't even have my fenders rolled. It was super close to rubbing though, only mm of clearance, but I was running ~-2.3 degrees of camber in the rear.
Old Mar 18, 2009 | 10:21 PM
Wannabe6MT's Avatar
-MN G Crew-
I have no idea what im running. I remember i used to rub going around corners if somone was in my backseat before i got my fenders rolled. Also rubber going over bumps when i had luggage in the back.
How do i check camber?
Old Mar 18, 2009 | 10:54 PM
Beebo's Avatar
Janik dont worry so much and just do it
Old Mar 18, 2009 | 10:58 PM
Wannabe6MT's Avatar
-MN G Crew-
Im just making sure. Dont want to hurt anything on the baby G
Old Mar 18, 2009 | 10:59 PM
1SlowSedan's Avatar
lmao
