can 2003 stock 350z rims fit 2004 g35 sedan?
Old Mar 20, 2009 | 02:06 AM
Gorg3ou5's Avatar
those set or rims....
lmk please...
asap thanks!
Old Mar 20, 2009 | 02:07 AM
jutn35's Avatar
G35 Coupe
yes
Old Mar 20, 2009 | 02:09 AM
Gorg3ou5's Avatar
im trying to put it on but it wont go straight on to the hub....???
Old Mar 20, 2009 | 02:17 AM
Lucky-G's Avatar
Then you've got a bigger problem. The bolt pattern is the exact same.
Old Mar 20, 2009 | 05:32 AM
TurTLe*'s Avatar
then you messed up somewhere down the line.
there should be no reason why it wont bolt up. another question would be WHY would you want those? they are not that appealing visually... i assume because it has good tires on or winter wheels.
Old Mar 20, 2009 | 02:58 PM
jutn35's Avatar
G35 Coupe
WAIT ?! are you sure your putting the right tire on the right hubs, like my OEMS the front are a bit smaller than the rear, theres some little bolt on the hub that prevents you from putting the wront wheel on
Old Mar 20, 2009 | 03:41 PM
nghiars's Avatar
+1... hence the other comment about OP having a bigger problem than getting the wheel mounted...LOL
Old Mar 20, 2009 | 03:43 PM
Jeff92se's Avatar
Red Card Crew
Isn't this nub mounted on the hub? ie.. only on the coupe? Or is it on the wheel? Of all the sets of Z wheels I've had, I have not noticed any extra stud on the wheel.
Old Mar 20, 2009 | 10:42 PM
AARONHL's Avatar
Those look heavy!!!
Old Mar 21, 2009 | 12:55 AM
Jeff92se's Avatar
Red Card Crew
They are about the same weight as the coupe 18s and any of the various 350z 18s except the track editions
Jusseth
Sep 13, 2020 12:25 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
