cabin heating cooling issue - is it a common problem?
Old Mar 23, 2009 | 11:41 AM
ajg35's Avatar
I have had 80k problem free miles with my 03 sedan. However, this issue has happend three times during the past two weeks. The climate control temps would go up to 90, and then the fan would turn on high. Regardless of what I would push, there was no changing it. it was stuck on 90 and fan on high! It would stay this way until the key was turned off and reset. It does have the auto dual climate controls, so I'm wondering if it's a bad board, sensor, or something similar that might be causing this. Any toughts?
Are there known problems with the earlier sedans related to the heating cooling system controls?
Old Mar 23, 2009 | 12:08 PM
5150DS's Avatar
What vent is tha fan blowing through? If it is the defrost vents then it could be a vaccuum problem. Maybe a hose came loose. This is done as default to keep the window clear in bad weather.
Old Mar 23, 2009 | 12:22 PM
ajg35's Avatar
I don't recall for sure... I'll have to pay close attention if it happens again.
Old Mar 23, 2009 | 01:11 PM
Tollboothwilley's Avatar
2003 and 2004 stock climate control boards/buttons have issues with the circuitry. You have 2 options the way i see it if it is the problem.
#1) there is a company that will fix the stock circuit board
#2) there are double din conversions that will replace the HU but you will also have to replace the radio.
Old Mar 23, 2009 | 05:20 PM
ajg35's Avatar
good to know...thanks for the info. regarding the double din - is this swapping it out with the newer 05-06 style or something else? Thanks!
Old Mar 23, 2009 | 08:23 PM
Mustang5L5's Avatar
Nope, aftermarket.
It's a common prob on 2003's. Do you happen to notice if your radio acts odd too at the same time? The display freezes and none of the buttons work BUT you have your steering wheel controls??
The prob is the radio board is intermixed with the HVAC board. The stock radio messes up and takes out half the interior electronics
The fix is a double din JDM faceplate, a JDM A/C controller and an aftermarket double din radio unit.
It's gonna cost you some coin
Old Mar 23, 2009 | 10:16 PM
ajg35's Avatar
Originally Posted by Mustang5L5
Nope, aftermarket.
wonderful...well, it hasn't happend but the few times, so I'll wait until it becomes a problem before deciding my options. Thanks again...
Old Mar 24, 2009 | 05:11 PM
ajg35's Avatar
will changing the front plate electronic board fix the problem or is it more of an internal issue? I see the front plate boards for sale quite often and typically at a good price.
chinee
Jun 10, 2024 07:48 PM
champppy
Mar 31, 2020 12:25 PM
Smittie20
Aug 9, 2015 04:29 PM
Phenomenon9
Aug 9, 2015 01:34 AM
