18" rims with F 248 & R 285/30R18 tires on 06 G35 sedan?
Old Apr 9, 2009 | 08:29 PM
BH818's Avatar
my orginal tire size is 215/55r17 on 17" rims all 4 of them. I now have
225/50r17 now. My friend is selling his rims with tires. 245/35R18 in the front and 285/35r18 in the rear. What do I have to do to fit them on my car? lol
Old Apr 9, 2009 | 08:31 PM
6MTFTW's Avatar
What size/offset are the wheels?
Old Apr 9, 2009 | 08:33 PM
BH818's Avatar
18" rims front is 8.5 width and rear is 10" width 45 offset. the rims are off of a 07 350z
Old Apr 9, 2009 | 08:43 PM
G SEDAN's Avatar
with +45 front and rear......it should fit fine considering they are both 30 series. if anything you may just need a simple fender roll in the rear.
I must caution you though.....245-30-18 is really fvcked up size........its too thin and will look gross if your car is not dropped. You'd need to dump that bad boy for it to look good.
Old Apr 9, 2009 | 11:17 PM
BuckeyeInMI's Avatar
225/50r17 now. My friend is selling his rims with tires. 245/30R18 in the front and 285/30r18 in the rear. What do I have to do to fit them on my car? lol
Your speedo/odo are going to be WAY off. Stock diameter is 26.3", the 285/30-18 is only about 24.8", which is an 11% difference in circumference, so an 11% difference in your speedometer and odometer.
The fronts are, to put it mildly, simply ridiculous. They are 18% smaller than stock circumference. I had to calculate it based on the numbers because Tire Rack and a few other sites do not carry any tires that are 245/30-18.
My suggestion would be to map out various routes around town that don't have any moderate road imperfections because your ride is going to be very rough and your chances of bending a wheel are pretty high with such a short sidewall (less than 3" from the inner bead to the top of the sidewall).
Attached Thumbnails 18" rims with F 248 & R 285/30R18 tires on 06 G35 sedan?-low_0015.jpg
Old Apr 9, 2009 | 11:39 PM
BH818's Avatar
Sorry its 245/35r18 front with BFGoodrich g-Force T/A KDW 2 tires
285/35r18 in rear with Hankook ventis v12 evo tires
Old Apr 10, 2009 | 12:25 AM
BH818's Avatar
Old Apr 10, 2009 | 11:15 AM
6MTFTW's Avatar
Can we say, "HOLY VDC FAIL"???
Old Apr 10, 2009 | 12:20 PM
G SEDAN's Avatar
yeah with that much tire height difference front and rear....it's a crap shoot as far as VDC tripping out.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
