Battery + Brake (!) dash lights ON
Old Apr 14, 2009 | 12:35 PM
kwiniarz's Avatar
Hi Guys,
This issues i back on my car, just wondering if anyone has a solution
The Brake and Battery lights are lit up on my dash, they were dim but now fully solid.
Alternator is charging, 14.8 when on 12.8 when off. Any ideas?
Edit
actually anyone know how many amps the alt should be putting out?
Old Apr 14, 2009 | 01:17 PM
maciejk's Avatar
i believe its 110 amps
Old Apr 14, 2009 | 01:42 PM
fluxcapacitor's Avatar
i've always wonder what does the ( ! ) mean?
Old Apr 14, 2009 | 01:47 PM
apintojr's Avatar
i get that when my rims are on and i travel on the highway. after a certain amount of miles of straight driving i get the (!)
from what i was told in the past is the tps sensor. when my rims are on i get this. when i put the stockies back on, it never comes on.
Old Apr 14, 2009 | 01:49 PM
^^ thats weird because when i drive on the freeway for a while then it comes on but i have stock 18s. i heard its the tps sensor too but what cud be wrong?
Old Apr 14, 2009 | 01:56 PM
apintojr's Avatar
hrmm. no idea. did u try the dealer? i have no issues with my stock 17's on the car.
Old Apr 14, 2009 | 02:00 PM
kwiniarz's Avatar
110 amps, that sounds right
anyone know how to test amps for an alternator properly?
Old Apr 14, 2009 | 02:24 PM
maybe one of my sensors is bad
Old Apr 14, 2009 | 03:39 PM
kwiniarz's Avatar
going to do my alternator tomorrow as two dealers say that's it. Hopefully that will fix it.
Old Apr 14, 2009 | 05:17 PM
kvangil's Avatar
Most likely the alternator needs replacing. I believe that's Nissan's standard indicator for an alternator going bad. My Maxima did that, and I had to replace the alternator.
Old Apr 14, 2009 | 05:42 PM
does anybody know how to know if one of ur tpms sensor is bad?
Old Apr 14, 2009 | 06:17 PM
Mustang5L5's Avatar
Is this a question about TPMS or alternators?
The (!) light is the early TPMS warning light. It is YELLOW in color and was later replaced with a version with the tire in the middle
The BRAKE (!)(P) light is RED and is your parking brake, low fluid and other brake issue related warning light
Old Apr 14, 2009 | 06:47 PM
RADIOGUY21's Avatar
brake + battery light means there is a fault in the charging system, typically caused by a bad alternator.
Old Apr 14, 2009 | 07:35 PM
ttrank's Avatar
Grocery getter
Bit if you are seeing 14.8v at idle the alternator is working fine.
Old Apr 14, 2009 | 10:45 PM
kwiniarz's Avatar
that's the strange part, 14.8v is fine, but dealers says something about diode ripple. This happened a few weeks back and once a year ago. I've duplicated the battery and brake leds by pulling the 10amp alternator fuse. I;ll let you guys know when the new alternator goes in, should be thursday for sure. For now, back to driving the Audi TT
