2004 Headlight/Foglight Replacement
Old Apr 26, 2009 | 03:18 PM
turboner's Avatar
So recently I have noticed that my passenger side fog light bulb is out. I am looking for replacement bulbs and I am wondering if these will fit the fog light.
Also if the brand is reliable.
http://www.eautoworks.com/product-Nokya-23066.htm
I am also looking to change the halogen bulbs for the headlight low beams/ high beams. First are there 2 different bulbs, one for low beam and one for high beam, or is it just one bulb?
Any help is greatly appreciated!
Old Apr 29, 2009 | 05:39 PM
gmacgs19's Avatar
2 bulbs and to relpace the headlight bulbs they say you have to take the grill and bumper apart then take out the headlight assembaly but i just did mine 10 min ago and the easiest fastest way is take the front wheels off take the front of the fender protectors off and you can get to them from there unscrew the captwist the ballast 1/4 turn and for the top bulb ou dont need to take the lock spring out just pop the two ides and lift it the bulb will fit under it my way takes about 30 min the way the other people say to do it takes an hr -hr and a half each side
Old May 1, 2009 | 01:58 AM
turboner's Avatar
thanks a lot man
Old May 8, 2009 | 02:46 AM
turboner's Avatar
oh so basically i ordered 28 dollar luminics, did not remove bumper or wheels and it was easy
took like 20 minutes
Old May 8, 2009 | 09:54 AM
gmacgs19's Avatar
how did you do it without removing the wheels did you just reach in the wheel well?
Old May 8, 2009 | 10:08 AM
g35freak86's Avatar
Yes, turn the wheels on whichever side you are working on to gain access.
Be careful with those luminics bulbs. Not to scare you, but I had a big issue with them (some others have as well). They ran so hot and caused smoking inside the headlight itself and melted my headlight wire harness. Needless to say, those have been out of my car since the day I put them in.
Old May 8, 2009 | 10:57 PM
jakeup93's Avatar
Hi, I bought Nokya yellow bulbs. I think they are very nice for the price. $10 shipped used on ebay. They have been going strong for several years. I think that it helps bring out color compared to the stock hid plus more output. If I could do quad hid's, I def would.
TheKnite
Aug 14, 2015 07:59 PM
Srinidhi
Aug 7, 2015 03:38 PM
vstypicals
Jul 20, 2015 10:55 PM
igking
Jul 19, 2015 01:12 AM
