G35 Sedan Suspension Picture Compilation Thread
Old Oct 20, 2014 | 07:41 PM
  #1546
Thaaa_king's Avatar
Old Oct 20, 2014 | 08:37 PM
  #1547
Thaaa_king's Avatar
I need to go wider
Old Jan 7, 2015 | 06:23 PM
  #1548
sumptimwong's Avatar
Tein H-tech (for 350z) and Koni Yellows (also for 350z).
As expected, it lowered the ride about 1-1/4" all around (measured from fender to floor before and after). As you may be able to tell, the front fender gap is still a little bit more than the rear. I'm on the OEM 18's with 235 rubber. No alignment yet, but camber seems reasonable as-is from a visual test. No camber kit unless the alignment reveals that one is necessary.
I have the OEM sport springs (mine is a 6MT) for sale if anyone is interested.
Old Jan 7, 2015 | 09:19 PM
  #1549
Texasscout's Avatar
If the springs are new or have been off a long time, it will still settle 1/4" - 3/8" more.
Old Jan 26, 2015 | 12:06 AM
  #1550
mannypr24's Avatar
My G35
I just want to share my g35. Nothing fancy, 19 Rays on Z setup. I hope you like it.
Old Jan 26, 2015 | 12:12 AM
  #1551
lazyieg's Avatar
Originally Posted by BazookaJoe
BC Coilovers, spc front and rear adjustable camber/toe. On SSR GVT01 19x9.5 ET 38 and 19x8.5 ET 35 with 5mm spacer. I should be the first guy in the states running these on a G35.
Did you need to roll fenders?
Old Feb 23, 2015 | 07:09 PM
  #1552
Hypez's Avatar
Lowered on revised Z springs with OEM sport shocks and 19" Rays 225/40 245/40. I've had the springs on the car for over 6 months now and I'm curious to why the front drop is uneven? Front left has a 3 finger gap, whereas the front right has 3 1/2-4 fingers Wondering if anyone had this issue, camber is FL -1.2 / FR -0.9 if that makes any difference.
Old Feb 24, 2015 | 08:57 AM
  #1553
Texasscout's Avatar
Are you sure they had the same "color code" on them?
Old Feb 24, 2015 | 02:22 PM
  #1554
Hypez's Avatar
Yes they all have matching color codes.. fronts have 1 pink/ orange dot and the rears have 2 red dots and 1 purple dot.
Old Mar 4, 2015 | 03:08 PM
  #1555
mannypr24's Avatar
Hi! anyone knows if we can use Z setup on a G35 2007 sedan?
Old Mar 4, 2015 | 07:02 PM
  #1556
thegreatkwijibo's Avatar
^no you have a v36 which is not compatible with the v35/z33 suspension components.
Old Mar 9, 2015 | 11:03 PM
  #1557
Camacho35's Avatar
Originally Posted by FlyingLumpia
I believe he had tokico d-specs on his car and those are 20s
No camber kit?
Old Mar 20, 2015 | 11:24 AM
  #1558
Camacho35's Avatar
Originally Posted by dan|el
Tein basics.. The front is maxed out and the rears are maxed plus 1 collar removed..
I want this stance exactly. What teins did you get? And how low were they??
And another thing, what do you mean collars removed? Thanks man! Beautiful G!!
Old Mar 20, 2015 | 11:34 AM
  #1559
Texasscout's Avatar
Exactly what I did, but I run 245 40 19's, fills up the fender opening a bit more. Rides good too. I tried 35 profile and bent too many rims.
Old Mar 20, 2015 | 02:03 PM
  #1560
dominate's Avatar
You can even lower than that ride height with Stance coilovers.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
