CD player issues
Old May 18, 2009 | 09:10 PM
Tunerz_Store's Avatar
CD player issues
I unhooked the negative battery terminal to bleed the brakes. Ever since hooking it back up, my freaking cd player won't play cd's and won't eject them either. It doesn't ever read any type of error, it just keeps trying to eject the cd and then tells me to press eject and repeats the process. Does one thing have to do with the other or just a coincidence that this unit is now jacked up like the last one I had replaced under warranty 8 mos ago? Lastly, are parts replaced under warranty covered for another year even if the actual warranty is no longer active?
Old May 18, 2009 | 10:24 PM
geew1z's Avatar
The bose radios in the g's seem very prone to this failure. I doubt they will replace it since the car is out of warranty...otherwise it is like 275 for someone to fix it..
Old May 19, 2009 | 12:52 AM
Paintballa915's Avatar
actually jus the refurbished stock stereo head unit alone is 395 thats if u can install it urself i think installation was somethin like over a 100 more i know what ur goin thru n it sucks im stuck wit the radio everywhere i go but next week im puttin a new deck in the car n slowly work on puttin a whole system in
Old May 19, 2009 | 04:02 PM
According to the warranty manual, if a CD/Radio/Tape player is replaced under warranty, then the replaced unit is covered under a 12 mo warranty unlimited mileage or the remaining time of the factory warranty, whichever is greater. So in my case, the unit was replaced in Aug 2008. The factory warranty expired in Oct 2008. So the 12 mo warrant is still in effect and the unit will be replaced. The unit should be here in a couple days and installed while I chill in a loaner.
Old May 19, 2009 | 04:39 PM
pwebb's Avatar
the cd/radio units are known to fail. also, the circuit board (finisher piece with all the controls) can be at fault. this is more rare, but i've done quite a few radio units and still the same symptoms.
Old May 19, 2009 | 10:56 PM
lexusk8's Avatar
I got my Bose unit replaced under warranty about 3 years ago, and it's still working OK to this date (other than the fact that slot #4 cannot take a CD, the CD keeps going in and out so I have to eject it out).
Old May 19, 2009 | 11:08 PM
oo G35x oo's Avatar
I have only had my 04 G35x for less than 24 hrs before i had to leave it in the airport parking lot while i am on a business trip. So, i haven't even had time to play with this at all, but my stereo says 6 discs but while one disc is loaded and i try and load another it doesnt let me. Could I only have a one disc player or were all bose systems 6 discs?
Old May 19, 2009 | 11:27 PM
lexusk8's Avatar
^ All factory systems in the G35 (Bose or non-Bose) load 6 CDs.
What does the screen of the head unit say when you try to load another CD? Usually it should say "SELECT CD" and you choose slot 1, 2, 3, 4, 5 or 6.
Old May 19, 2009 | 11:51 PM
tbrillz35's Avatar
These systems blowwwwww
I like the bose speakers, but my head unit had to get replaced because of the infamous CD ERR FO message
Thank GOD it was still under warranty.
Danielek
Sep 20, 2015 12:08 PM
Frostbite91
Aug 20, 2015 07:20 PM
Higbee89
Aug 16, 2015 09:36 AM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
