BBK on the X?
Old May 19, 2009 | 01:43 PM
ProfanityPete's Avatar
Is there a DIY for Brake Bleeding?
Old May 19, 2009 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
I mention the method I used in my link. It's hardly worth explaining more than the picture shows. Unless you need to be reminded to keep the fluid up in the reservior and to loosen/tighten the bleed screw
Old May 19, 2009 | 04:21 PM
BuckeyeInMI's Avatar
Originally Posted by ProfanityPete
Hey, anyone know of a BBK that fits on the X? I'm looking to get one for the X, and I have yet to find any that will fit the X. Anyone have one on here?
And then my second question is are there any that also will fit under OEM 17s?
Your first option is useless, as I said my calipers are going, but thanks anyway.
My first option answered your first question, "a BBK that fits on the X?". The first option does fit an X. It just won't fit under a 17" wheel, but that was your second question. My second and third options deal with your 2nd question and your caliper problem.
I can only answer the questions you ask, and I provided an option for what you asked. If you can't clarify your questions, don't blame me for answering the ones you actually posted.
Old May 19, 2009 | 07:20 PM
FlyingLumpia's Avatar
I had my 17s on with a 5mm spacer. I got them from fastbrakes.com Here is a pic of it.
Old May 19, 2009 | 07:26 PM
Wow. Which BBK is that?
Old May 19, 2009 | 07:27 PM
Wilwood 4 piston with a brembo rotor.
seagrasser
May 3, 2022 09:43 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Jiggerjuice
Dec 6, 2015 10:29 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
