Sedan Hotchkis swaybar settings
Old May 18, 2009 | 09:26 PM
JAB75's Avatar
Will be installing Hotchkis swaybars on my 2003 base sedan along with a VLSD this week. Any opinions on what the best swaybar settings front and rear should be?
Old May 18, 2009 | 10:27 PM
JAB75's Avatar
Keeping the rear at medium
A) Front Hole 2 148% , Rear Hole 2 225%
B) Front Hole 3 182% , Rear Hole 2 225%
C) Front Hole 4 229% , Rear Hole 2 225% Seams like a linear increase to both
Lower rear to low
D) Front Hole 3 182% , Rear Hole 1 180% Seams like a linear increase to both
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Old May 19, 2009 | 07:16 AM
sloppymax's Avatar
Hotchkis recommends front hole 4, rear hole 1 in the manual. For my 06, which has slightly lower %s in the front, I prefer front hole 4 and rear hole 2. I would try what Hotchkis recommends first and see how it suites your driving style.
Old May 19, 2009 | 08:08 PM
JAB75's Avatar
Manual I downloaded only shows 3 holes in front (wrong) and just states stiffest front and softest rear so not so sure they ment hole 4. This may have been a 3 hole front system originally???
Old May 19, 2009 | 09:43 PM
sloppymax's Avatar
I did notice that. I emailed them a while back and was assured to initially set it in the hole furthest from the end of the bar, which they identified in the email as the 4th. Of course some might not want it that stiff.
Old Aug 11, 2010 | 06:12 PM
sierrahpbt's Avatar
I just installed mine and set the front at 3 and the rear at 2. If I set them at the stiffest settings what can I expect with handling. Is there a downside to using the stiffest settings?
Old Aug 11, 2010 | 06:58 PM
boostedforlife's Avatar
if you taking the turns hard on un even roads, youll lose more traction.
Just started on med med or low low and work your way up and see how you like the car to handle, more over or under steer
Old Aug 11, 2010 | 09:42 PM
4drmadness's Avatar
damn i forgot my settings!
Old Aug 12, 2010 | 12:28 AM
3truman's Avatar
not that it matters but my stillen sways are both on stiffest settings. stiffer rear setting will increase oversteer
Old Aug 12, 2010 | 07:10 AM
sierrahpbt's Avatar
I had my favorite mechanic install mine a few days ago. How big of a job is it to adjust them?
Old Aug 12, 2010 | 07:25 AM
sloppymax's Avatar
17mm open ended wrench to the nut in the front. Push the end link out of the existing hole and move it to whichever you prefer. Tighten the nut back down. Same process for the back except its 14mm and pretty sure I used a socket.
Old Aug 20, 2010 | 04:10 PM
allmotorsedan's Avatar
My front is at the 3rd stiffest setting, and rear at the stiffest setting. Still using stock link pins!! It handles really great!! Also have Tein coilovers as well
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
reaper76
Aug 5, 2015 10:13 AM
wylin
Lights
Jul 18, 2015 06:12 PM
mushu
Jul 15, 2015 03:55 PM
