20" Rims
Old May 20, 2009 | 01:45 PM
kevin3751's Avatar
20" Rims
I want to get 20" rims on my 05 G35 Sedan. It already has 18" rims on 235/45/18 tires. I was wondering if I can get 20" rims without modifying anything else on my car, I do not want to lower it because it will mess with my warranty. If i were to get 20" rims, what size tires would be my best bet?
Old May 20, 2009 | 01:57 PM
G SEDAN's Avatar
i was wondering if you even searched before starting this thread.
Old May 20, 2009 | 02:10 PM
kevin3751's Avatar
Yes, many times. Can't seem to find a clear answer, thanks.
Old May 20, 2009 | 02:13 PM
Dubi2087's Avatar
Yes you can do 20" you will be running a 245/35R20 and a 275/35R20 you just need a sedan offset which is higher than the coupes.
Old May 20, 2009 | 02:33 PM
G SEDAN's Avatar
275/35/20 is too tall........
I'd recommend doing 245/35/20 Fr and 275/30/20 Rear.
You want to keep your sidewall height as close to stock as possible.
Front Offset range on a typical 8.5 inch rim +35mm to +38,
Rear Offset range on a typical 10 inch rim +40mm or higher.
This setup will be very flush to the fender, and I know you don't want a drop, but rims on stock heigh looks out of place to me. You will want a drop after getting rims I gurantee you.
Old May 20, 2009 | 03:14 PM
Dubi2087's Avatar
if you do 245/35R20 and 275/30R20 your front tires will be about 5 to 10mm taller than your front tires.
kevin3751's Avatar
mmm ok, well thanks. Does anyone have any pictures with 20" rims NOT DROPPED?
Old May 20, 2009 | 03:16 PM
kevin3751's Avatar
What about 245/30/20 and 275/30/20....
Old May 20, 2009 | 03:26 PM
G SEDAN's Avatar
The tire size you suggested, 275-35-20 is way too tall for the g35 at 30mm+ taller than stock.....it has a diameter Difference of 4.58%.......beyond the safe range.
Old May 20, 2009 | 03:31 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
20x8.5 +35-40 with a 245/35/20
20x9.5 +45 with a 275/30/20
20x10 +50 with a 275/30/20
END THREAD.
Old May 20, 2009 | 03:32 PM
G SEDAN's Avatar
^^^^The wheel/tire has spoken.
/thread
Old May 21, 2009 | 10:01 AM
risingson's Avatar
not likely.
Old May 21, 2009 | 11:41 AM
psedog's Avatar
Back in SD**
^^^ I do, I'll post em up tomorrow when I get home. (right now I'm in the middle of the ocean )
Old May 21, 2009 | 07:44 PM
ttrank's Avatar
Grocery getter
Please read the FAQ before starting another thread.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
