Radio don’t work/ A/C stay on 75 degrees FIX
Old May 24, 2009 | 01:59 PM
SDGenius's Avatar
lookin' forward to the fuse diagram
Old May 24, 2009 | 02:59 PM
DudeMan's Avatar
its right near the dead pedal on the drivers side
hope its the same problem for you guys
and check every fuseeee and near the battery check all of them too just in case you never know
Old Oct 1, 2009 | 02:29 AM
willcho415's Avatar
I have a double din with aftermarket HU. SInce last week while driving the AUTO A/C would also turn on its own and it would take me few seconds to change its settings. Sometimes the buttons doesnt even work! Ill check the fuse out tomorrow...hopeuflly it fixed it
Old Oct 1, 2009 | 11:49 AM
KDmospd's Avatar
Thumbs up
Originally Posted by KDmospd
For anyone that ever run into an issue were your radio don’t turn on and the A/C stay on 75 Auto but has no control functionality, check the fuse # 15 that’s in the area by the battery. I did a lot of research but did not find a straight answer other than taking the car to the stealership or sending my radio unit off for as long as a MONTH and paying $150-$200 (Sending it off), $350 (used), & $550 - $600 (dealer). When I get a chance I’ll try to scan or make a diagram of the fuse box by the battery sense I couldn’t find anything on Radio fuse for 2005 Infiniti G35x on Google.
Now I get to have a Happy Memorial Day to ME DOMO
For anyone that read this thread, don't waste your money on buying an aftermarket unit or anything else until you try this. Maybe when I created the thread I should've posted "FIX" and then the title of the thread. Ignore the first couple of posts under the main
HERE IS THE FIX - check fuse # 15 that’s in the area by the battery, UNDER THE HOOD...
This worked for me and only cost me the price of a box of fuses or did I use a spare fuse... either way it fixed it....
Old Jan 5, 2010 | 10:48 PM
farsey's Avatar
hey
can some one help with this i live in sanjose area my car start doing that today is there any shops around here that i can go to?
Old May 11, 2011 | 02:22 AM
TemjinX2's Avatar
anyone know what size fuse it is? its pretty small, i didn't see a number or anything on the fuse other then the amp rating.
Old May 11, 2011 | 03:19 AM
mysoda's Avatar
i don't think is the fuse. usually is the head unit. i have a a head unit for non bose system if anyone is interested.
Old May 11, 2011 | 06:30 AM
ronniepetras's Avatar
I have the same problem my unit turns off & the a/c starts blasting till I smack the unit couple times turns back to normal I doubt it's the fuse
Old May 11, 2011 | 07:15 AM
KDmospd's Avatar
I will tell u the size when I go outto my car
Old May 11, 2011 | 01:46 PM
Intense_Geeez's Avatar
omg i should have came here a looooong time ago...
i also have a 03 G35 sedan and my radio/ac is doing the same thing.
BUT.... my ac is stuck on 60 degrees and gets cold as a mug
but after reading all of the posts im goin to attempt to check my fuses this evening and hope that i can find which one is the problem and get it taken care of.
preshate the heads up!!!
Old May 12, 2011 | 11:28 AM
NFSP G35's Avatar
? = 2B || !2B
Solution is a new head-unit.
Stop-gap fix is to beat your OEM head unit like the read-headed step child that it is! (No offense to any soulless gingers that may be reading this)
Old May 12, 2011 | 11:32 AM
iamericgee's Avatar
i have a coupe and i have this problem once in awhile i will check my # 15 fuse like op stated
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
gatorglaze
Sep 10, 2015 12:03 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Frostbite91
Aug 20, 2015 07:20 PM
Frostbite91
Aug 12, 2015 05:16 PM
