DIY Info
Old May 24, 2009 | 11:12 AM
Mk2Fever's Avatar
DIY Info
So I've been searching around the forums to get an idea for what I want to do to my car, and have decided that a lot of what I want to do to my car is DIY, such as blacking out the inside of my headlight housings and painting my grille a gloss/flat black.
Does anyone know if there are any good 'write-up' DIY threads where I can learn how to do some cool little tweaks to the G? I saw the video threads but they're a little more maintenance oriented.
Also, does anyone know where to find the thread that gives the steps for resetting the ECU? Thanks again!
Old May 24, 2009 | 11:33 AM
LyricallySick's Avatar
Did you check the stickies and other forums?
https://g35driver.com/forums/faq-diy...ple-steps.html
https://g35driver.com/forums/g35-sed...eo-series.html
Old May 24, 2009 | 11:34 AM
G35Papa's Avatar
https://g35driver.com/forums/media-s...rille-diy.html
https://g35driver.com/forums/lightin...eadlights.html
Look in the tech forum for the ECU resetting. I think its a sticky
Old May 24, 2009 | 03:07 PM
Mk2Fever's Avatar
AWESOME.
thanks guys.
Also, a few little questions while I have you here. When turning the car off, do your cars make a little sputter noise? Is that normal?
Sometimes at low speeds I hear clicking coming from the front right wheel well area when accelerating, I thought it was a creaky suspension bit, but if I push on the car, no creaks. Any ideas?
Old May 24, 2009 | 03:32 PM
Blue Dream's Avatar
I drove ttrank's car solo
All I hear when I accelerate is y-pipe, z tube, and that addictive VQ warble
Old May 24, 2009 | 09:36 PM
dineth00i30's Avatar
do you put premium gas? maybe it will help the sputtering.
Old May 25, 2009 | 12:57 AM
Mk2Fever's Avatar
93 religiously.
Old May 25, 2009 | 03:14 AM
sistom's Avatar
are you sure it's coming from the front and not the back?
Old May 25, 2009 | 10:39 AM
Mk2Fever's Avatar
I'll try and make a recording and post it on here, it's a weird creaking sound, and sounds like its reacting to the car's weight shifting backwards on acceleration.
Old May 25, 2009 | 12:55 PM
5150DS's Avatar
Originally Posted by Mk2Fever
AWESOME.
thanks guys.
If it is when you first start out, it might be the Anti lock brake self test.
5150DS's Avatar
All DIY's should be here in the tech section: https://g35driver.com/forums/faq-diy-11/
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
