D-Specs with Eibach Pro-Kit Springs?
Old May 28, 2009 | 09:38 AM
TheSwiftDrift's Avatar
My Car: 2005 G35 Sedan 6MT
After looking over the great suspension thread and dozens of others I believe I would like to get the Tokico D-Spec DSP-7 struts as an addition to my current Eibach Pro-Kit Springs.
Would anyone advise against this?
Should I be going with the DSP-9's because of the shorter rods on the rear shocks?
Do the eibach springs mount up well on the front d-spec struts?
If you have ran this setup please share your experience.
I drive 60 miles a day. (50 freeway, 8 urban, 2 rough city roads)
Thanks to all!
Old May 28, 2009 | 11:14 AM
dahkyne's Avatar
^ this is my current setup. though, i run eibach pro-kit springs for a 350Z. IMO, it works very well, though others have also found the regular tokico HP shocks (blue) work well with pro-kit springs too.
if you're running pro-kit springs for a sedan, get the DSP-7 kit, as the rear spring is not as short as the Z version. i would set the damping rates on all 4 shocks to -3.5 or -4 from full stiff, initially, then adjust to your taste from there.
in order to adjust the rear shocks, you'll need adjuster cables, which I have a spare pair of. PM me if you need them.
Old May 29, 2009 | 11:51 AM
CandlestickPark's Avatar
ill Sedan
I had this exact setup for about 20K miles, per advice from dahkyne. I was very pleased with the performance the Pro Kit/D-Spec (DSP-7) combo. I chose the D-Specs over the HP shocks for the dampening adjustment (which I did use). Everything mounts up fine, no problem.
Old May 29, 2009 | 11:09 PM
bowzer's Avatar
I too have the d-spec shocks paired with 350z h&r springs. Set to 3.5F and 4R, they are bit stiff for my daily 75 mile commute so I will need to adjust a tad softer. But for spirited driving the setup is perfect IMO.
Also, people have talked about the rear adjuster cables being needed, however on my 03.5 they are easily reachable behind the back seats. Pull the seats forward, lift the seat flap and take off the black strut cover. Not sure if this varies per year/model though
Old Jun 1, 2009 | 02:23 PM
Thanks for the feedback.
Thanks to all who responded. I will be ordering up the D-Specs some time this month!
Old Jun 26, 2009 | 02:23 PM
D-Specs Have Arrived
I will be installing my DSP-7's tomorrow with rear adjust cables. Thanks again.
Old Jun 26, 2009 | 05:20 PM
miltoda's Avatar
Please put up some before and after pics to show the ride height differences
Old Jun 26, 2009 | 07:36 PM
Axmily's Avatar
off subject but do the Tokico Hp Blue shocks and struts lower the car anymore? i already have Tein S techs.. any reviews?? thank you
Old Jun 29, 2009 | 09:16 AM
NO they do not lower the car anymore. The purpose of good shocks are to keep the pressure of your tires on the road even.
I installed the DSP-7's this weekend and it is a definite improvement over the stock red sport oem tokico's. They fit like a glove since Tokico is an OEM manufacturer for the Infiniti sport suspension.
Thanks again to all.
Old Jun 29, 2009 | 09:56 AM
Johnnyone's Avatar
Can you share pics of your car? I have the coupe prokit up front on my car and would like to see what they look like on all four corners.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
