horrible creak from rear deck when car is cold
Old May 29, 2009 | 08:45 PM
kniob's Avatar
Hey Everyone,
So I'm getting this HORRIBLE creaking noise coming from my rear deck. It seems to only happen in the morning when the car is still cold. When it's been sitting outside for awhile or later in the day when it's warm, I don't hear it at all.
When I bought the car, it had the issue of the rear cross bar (behind the seat) making horrible noises, but my friend and I fixed that.
This one sounds more like it is coming from back in the deck or from the window area. Anyone have any ideas on what is causing me to want to light the car on fire?
Thanks!
(incase you don't notice my sig, 2005 G35 Sedan)
Old May 30, 2009 | 08:03 AM
pwebb's Avatar
take out back seats, and c pillar trims to remove the rear shelf.
insulate all contact points with felt tape.
if you're lucky you're still under warranty.
Old May 30, 2009 | 12:16 PM
OCG35's Avatar
there was a TSB on this - I had mine done about 4 yrs ago... you might want to look it up and see if the dealer will honor it.
Old May 30, 2009 | 12:35 PM
pwebb's Avatar
actually that only applies from 2003-2004.
Old May 30, 2009 | 12:36 PM
pwebb's Avatar
also, that bulletin has you apply felt tape to the inside upper trunk finisher. this is found in the trunk.
Old May 30, 2009 | 12:45 PM
OCG35's Avatar
What I’m referencing is the “rear parcel shelf” – what I figured you referenced… when I have time I’ll look up my old invoice and the TSB.
rezendvous420
May 31, 2020 01:26 PM
TWASkyliner
Feb 8, 2020 08:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
NemesisGee
Aug 11, 2015 07:10 PM
