car overheated!!!
Old Jun 1, 2009 | 02:30 PM
bert039's Avatar
Originally Posted by LuXXXz
the car has 95k miles on it.
Yeh i havent been driving it. i changed the thermostat, and when its stopped the fan turns on and everything is fine. once i take it around the block it starts going up and my pops took it out and it overheated again. dammit i dunno wtf is goin on guys!
Does smoke still come out from the engine bay?
Old Jun 1, 2009 | 02:33 PM
LuXXXz's Avatar
not from the engine bay from the Radiator cap and we ended up opening it and it blew the cap off. (and yes we did it carefully)
Old Jun 1, 2009 | 02:37 PM
pwebb's Avatar
get a new cap, and bleed the system of air.
Old Jun 2, 2009 | 01:50 AM
Tollboothwilley's Avatar
guarantee its a coolant leak...
its the coolant hitting the exhaust that is causing the white smoke
i had a slight leak on a hose and had the same issue, i replaced the hose. fixed.
Old Jun 2, 2009 | 02:25 PM
LuXXXz's Avatar
im gonna try it guys! dont think its the water pump??
Old Jun 2, 2009 | 05:50 PM
erklep's Avatar
nah, no water pump, if you see white smoke, you have a definete leak.
Old Jun 2, 2009 | 07:48 PM
mesias's Avatar
First of all check for leaks. Go to an auto-parts, get a pressure tester for the cooling system, put the system on pressure (watch out for hot coolant, always release pressure from system before opening the radiator cap) and check for leaks. If the engine only leaks while driving it is very possible that the water pump is blown. If the systems leaked most of the coolant it is logic that the engine will overheat.
If there is no leaks and still the engine is overheating there are a few things to check. It is possible that the fans are defective, the thermostat is locked close, the cooling ducts are clog. Good luck!
Old Jun 3, 2009 | 01:41 AM
kittie's Avatar
may be a sticky expansion/evaporator valve...had same issue last summer
Old Jun 3, 2009 | 11:19 AM
Go find that leak. Running hot can cause other problems to occur so do it fast.
My leak turned out to be behind the intake manifold (plenum).
Old Jun 4, 2009 | 04:32 PM
LuXXXz's Avatar
where is that and did you have to replace it or clean it?
Old Jun 4, 2009 | 05:52 PM
DaveB's Avatar
The water pump is driven by the timing chain. It's a very simple device. If it were to fail, the engine would be making some very strange noises.
Old Jun 9, 2009 | 12:56 PM
LuXXXz's Avatar
ok guys i think i finally fixed the problem. changed the radiator cause it was leaking. and once i changed it i got the air out and its finally fixed. thanx guys for all the info
Old Jun 9, 2009 | 06:18 PM
bert039's Avatar
Congrats, I can't believe you went through all the trouble of buying and installing a new thermostat before even fixing the leak, but still at least the problem is fixed.
Old Jun 9, 2009 | 06:34 PM
GSedan03's Avatar
good job. yeah next time just try to look at all the smaller problems that it could be before jumping into changing the bigger stuff. but good job!
Old Jun 9, 2009 | 08:20 PM
  #30
mesias's Avatar
Great, what a relieve when this problems get solved, uh? Good luck!
