Rear Door Creaks
Old Jun 10, 2009 | 02:17 AM
thescreensavers's Avatar
Mr.202?
Rear Door Creaks
Hey guys, I read the "Sedan Rattle exorcism" Thread and I am going to the dealer tomorrow to get a part replaced. So I want to make sure if this is a solution to my rear door creaks to show them this info.
When I accel, Decel Go over bumps I hear creaking from the rear. What leads me to believe its the doors because if I open them they creak from inside the doors. About the center of the door.
https://g35driver.com/forums/g35-sed...-exorcism.html
Thanks
Old Jun 10, 2009 | 08:08 AM
al_macaroni's Avatar
You will want to look at the technical service bulletin: TSB05034 or NHTSA # 10015415. It details noise from the rear door with the window up.
Good luck.
Old Jun 10, 2009 | 08:23 AM
Parnelli's Avatar
I had the same issue in both rear doors. Regulator bolts are too long and were replaced under warranty.
Old Jun 10, 2009 | 09:55 AM
mcaron's Avatar
omg i have this problem too and it drives me CRAZYYYY. I find that in my car it usually happens when the windows are up and its somewhat cold out.
Old Jun 10, 2009 | 01:16 PM
Mr.202?
Good luck.
Ah so theres a TSB to fix this, Well I called up my dealer and they said I would need to go there first for a tech to hear it, gerr its a 35 min drive. I just tested my phone on speaker phone and you can hear it on the phone so I hope thats enough.
Old Jun 10, 2009 | 01:47 PM
OKStateG35's Avatar
Originally Posted by thescreensavers
Ah so theres a TSB to fix this, were can I find the tsb or Nhtsa info. I googled them both with almost no info
Go to www.infinitihelp.com and register for free. There is a list of Service Bulletins under 'Knowledgebase' at the top. You can download two .pdf's per day for free.
Old Jun 10, 2009 | 04:39 PM
RADIOGUY21's Avatar
I would print out that TSB and bring it to the dealer. I did that and they replaced them right away. Its been 2 years since they replaced the bolts and I havent heard them squeak since!
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
iknowitsfast
Aug 12, 2015 02:08 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
