HELP: Hotchkis Sway Settings on Stock Suspension
Old Jul 21, 2004 | 12:58 PM
SixFive's Avatar
I want neutral so what is the reccommendation from the experienced.
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Jul 21, 2004 | 01:51 PM
IQ9's Avatar
IQ9
Re: HELP: Hotchkis Sway Settings on Stock Suspension
I went middle/middle and it feels great.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
Old Jul 21, 2004 | 02:14 PM
Gsedan35's Avatar
You can use the experiences of other's as a starting point. But keep in mind the idea is to use the bars so you shape the behavior of the car to work with your setup and to work with you, the driver. Your goal will be to make the car behave in a way that you can extract the most from it. That may mean bar settings that are different then other drivers and car's that may have other setup differences your not aware of.
I know some people just want to set them and forget them, at least I did my part and explained the above so you can decide for yourself.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 21, 2004 | 02:46 PM
IQ9's Avatar
IQ9
Excellent point-I should have given a better answer.
Old Jul 22, 2004 | 08:04 AM
SixFive's Avatar
I want to start at neutral if possible and work from there. Just needed to know what you thought it took to get there. Gratis.
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Jul 22, 2004 | 09:52 PM
Q45tech's Avatar
Neutral is not a fixed place!
As the rear tire traction is shared with manuvers.........neutral with how many pound feet of which action: accelerating, decleleration, steady speed --- going straight or at what slip angle?
Also at what tire road interface friction coefficient [Dry concrete or dry asphalt or wet and how wet].......SEE THE PROBLEM.
Most racers set up for neutral at the apex of a certain corner at a certain speed and tire temperature.........under steering in over steering coming out.
Sepsis
Feb 12, 2020 02:05 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
wuppiedog
Aug 7, 2015 11:16 AM
vstypicals
Jul 20, 2015 10:55 PM
nascarbuff17
Jul 16, 2015 10:23 AM
