eibach springs...
Old Jul 22, 2004 | 09:30 AM
YngPhllyKd's Avatar
eibach springs...
sup G's...i know this was brought up a few times in earlier threads. But, i am considering buying the eibach springs for my G-Sedan. I have the sport tuned suspension. If i replace the springs with the eibach ones...will it make it better or worse? Advantages and disadvantages? Does anyone have a pics with the springs installed on their car? i wanna see the difference. Thanks.
KhaL
Eyyyy....u tryin to race or what?!
Old Jul 22, 2004 | 10:09 AM
SoCalTed's Avatar
Re: eibach springs...
I have a feeling this one may get moved to the suspension thread. but...here ya go:
My car is on the left, and the stock sedan is on the right. (I also have the NISMO body kit)
my car is also the sedan at the top of this page on the website's masthead.
I have the sport suspension. The ride is stiffer, and after almost a year I do hear more road knows when I hit bumps (eibach's actually settle a little lower than their claims.)
Mostly, i like the look of bringing the body down an 1"... makes it look much more aerodynamic and sportier.
Cheers, ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Jul 22, 2004 | 11:31 AM
iLLG35's Avatar
NY G-Squad G Race Driver
Ted if you had rims, OMG!!!!!!!! You dont even know how much it transforms your car, my car looks so diff. dropped and on rims, gert rims =) It will be even crazier lol.. Martin
Martin
2003.5 BS G35
Nismo Aero/Sport Package
Injen CAI
B+G Springs
ADR M-Classic 19's..
Old Jul 22, 2004 | 12:27 PM
shodog's Avatar
my expirence with eibach springs has been mixed. I had them on a Mustang I used to have and liked them. I currently have them on Taurus SHO. They give the car a cooler stance. initially they are softer than stock then firm up as the spring compresses. it's somewhat disconcerting at first.
I don't think I would change the springs on my G. the sport suspension seems stiff enough. The G with a body kit is low and any lower would mean scraping everywhere.
Jim
'03.5 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Jul 22, 2004 | 02:37 PM
SoCalTed's Avatar
Oh ya... you will scrape the nose on sharp driveways, inclines and parking headstones.
However, I have only scraped on a speed bump, hump or drainage rut once or twice in the time I have had the car... and that was when i had a full tank, 4 adults and a trunk filled with Costco goodies.
-T
Old Jul 22, 2004 | 03:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
SoCalTed..
Echo that, no scraping problems here.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
Borla TD, Z-tube, Eibach, 35%Tints</font color=blue>
Old Jul 22, 2004 | 04:07 PM
GBoy's Avatar
I decided to go with the coupe set up, found them for about
200$ and should lower the car about an inch with keeping
the same ride, hopefully a little firmer but might be best to check on the suspension forum, unfortunately I have not had a chance to get them on the car yet.
Gboy
Old Jul 22, 2004 | 07:03 PM
Gsedan35's Avatar
You mean you used the oem coupe suspension to lower your sedan, right?
Old Jul 22, 2004 | 08:20 PM
YngPhllyKd's Avatar
thanks for the pics and feed back. On twists and turns, will the car perform better than the stock sport suspension? i can tell the car look better a little lower though!
KhaL
Old Jul 23, 2004 | 01:29 PM
Gsedan35's Avatar
Well, the lowered center of gravity will help the car to a degree. However the springs progressive nature + the sport shocks lack of control will enhance poor weight transfer control. I've seen sedan's with the Eibachs on with the sport suspension in action, squat and brake dive are real issue's for the performance minded. Part of the problem is the fact that Eibachs development car was a non sport.
If the springs were not progressive and only rode on their peak numbers, things would be totally different. Progressive springs tend to make weight transfer control worse. And as the car enter's a corner, each side of the car is on wholly different spring rates. If you encounter a bump mid corner your suspension can yaw on differing spring rates and cause the car to spin or come out, this also worsens you ability to rain the car back in. As a example, let's look at a oem sport sedan in a corner and what poundage the springs leverage to the suspension. Oem springs do not have this problem because they are linear.
Oem sport sedan in left hand corner
LF 314 RF 314
LR 342 RR 342
Sedan w/Eibach springs (reverse numbers for right hander)
LF 259 RF 334
LR 359 RR 413
If you want a performance spring for the sedan, the best you can do are RSR springs ment for the 350Z, they will lower the sedan 1.6" however.
345/417
Next up would be Tein H-tech's ment for the 350Z, they would lower a sedan 1.3"/1.2"
358/375 (front's are progressive however, rears are linear)
Keep in mind that the oem sport shocks need to be taken off and replaced to really kick the car up a notch. I've had resevations in the past about the Koni's for these cars, due to some recent conversations with a few people, I have to say I've lifted those reservations.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 23, 2004 | 06:17 PM
GBoy's Avatar
I have purchased the springs and shocks from a coupe and
I believe they are linear, did see some issues with Eibach
so was scared off, and the complete Z350 set up would be too
bouncy for me so thought the coupe set up would lower the car about an inch and keep the same ride and maybe a little
firmer which is what I'm looking for at the moment..
GBoy
Old Jul 24, 2004 | 10:30 PM
CookG35's Avatar
I have the Eibach's with sport suspension. The ride quality is really about the same. It lowered the car nicely and the handling I would say is about the same, too. No problems scraping the front and I have the Nismo bumper. If I had to do it all over again I might go with the RSR's; they seem to bring the car to an equal height front to rear. I think the Eibach's are slightly too low in the rear.
seagrasser
May 3, 2022 09:43 AM
Kelvin Style006
May 23, 2016 03:47 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
