radio & a/c panel lights & switches not working !
Old Jul 10, 2009 | 01:25 PM
68_GT's Avatar
Angry radio & a/c panel lights & switches not working !
this is crap !
so this problem seems to come and go. The lights on the buttons are out for the a/c controls and none of them function, and all of the radio lights are out on the Bose head unit but the radio controls on the steering wheel work perfectly. The a/c blows cold air but it gets stuck on whatever fan speed it was on when the console panel goes out.
this has happened a few times but now it seems permanently screwed
this is on a 04.5 G35x Sedan
any ideas ???
Old Jul 10, 2009 | 02:15 PM
OKStateG35's Avatar
Very common problem. One of the reasons I went with an '05 instead of '04. I think the only fix is to replace the radio and AC circuit board. Do some searching on here. There are tons of threads on this.
Old Jul 10, 2009 | 03:09 PM
68_GT's Avatar
is this a factory recall that the dealer should fix ?
Old Jul 10, 2009 | 03:17 PM
OKStateG35's Avatar
I think there was a recall if your car was made between certain dates, but I don't remember the range. Most people just end up converting to a Double DIN setup because the factory radios are crazy expensive from the dealer and you risk the chance of it happening again.
Here is one of several threads on it.
https://g35driver.com/forums/audio-v...light-off.html
One guy mentions TSB's ITB03-007 & ITB02-062. I think the recall was a very limited range and may have only been for 2003 models.
Old Jul 10, 2009 | 03:27 PM
Blue Dream's Avatar
I drove ttrank's car solo
If you go with the double din, get the JDM not the Metra. Metra looks cheap, and JDM looks stock.
Old Jul 10, 2009 | 03:58 PM
68_GT's Avatar
I don't care about getting an aftermarket radio. I don't even know what a double din is ? What's the cheapest route to fix this issue ?
Old Jul 10, 2009 | 04:13 PM
OKStateG35's Avatar
Find a used radio and AC controls and hope they work?
Old Jul 10, 2009 | 04:24 PM
68_GT's Avatar
most say it's the radio but some have replaced the radio and still say it's the circuit board ?? WTF?
where can I get a refurbished Bose headunit from ?
Old Jul 10, 2009 | 11:58 PM
danster5's Avatar
i had the same problem but all i did was just swap out the radio for an after market and problem solved.
Old Jul 11, 2009 | 12:02 AM
SDGenius's Avatar
find a mobile audio guy in ur area, if you go anywhere else they'll charge $400-$500, just for them to send it off to get fixed. i found a local guy who's gonna pull me and my Wife's for a group rate + military discount, yay!!!
champppy
Mar 31, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
.cakestar
Engine - Intake/Fuel
Aug 25, 2015 03:17 PM
