Where is the outside temperature gauage sensor?
Old Jul 14, 2009 | 03:32 PM
joedaddy1's Avatar
Talking Where is the outside temperature gauage sensor?
just wondering...
Old Jul 14, 2009 | 05:31 PM
Mustang5L5's Avatar
I always wondered too. I assume it's somewhere in the front as it always rises from heat soak if i park for a while and cools off when i drive
Old Jul 14, 2009 | 06:20 PM
G SEDAN's Avatar
its somewhere behind your grill, i believe
Old Jul 14, 2009 | 07:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
Damn good question.
Old Jul 14, 2009 | 07:31 PM
CandlestickPark's Avatar
ill Sedan
Found this via google search: http://wiki.answers.com/Q/Where_is_t..._sedan_located
Q:Where is the exterior air temperature sensor for the 2005 Infiniti G35 sedan located?
A: between front bumper and radiator. they're known to go bad. 4yr 60k warranty on this part and all other parts on your g35 as well that aren't considered "wearable" like window/seat motors and audio/electronic parts. diagnostics consist simply of comparing reading with other g35s and the dealer will replace it
Old Jul 14, 2009 | 07:34 PM
BlueDevilBAMF's Avatar
^^^ Cool - good to know
Old Jul 15, 2009 | 05:05 PM
RADIOGUY21's Avatar
i wish there was a way to speed up the sensor reporting time. My black car can sit outside on a 95 degree day and the temp will display 130 degrees then slowly 10 minutes later display the correct temp.
Old Jul 15, 2009 | 05:30 PM
thescreensavers's Avatar
Mr.202?
this is exactly how every car I have ever been in worked. So its not just the G
Old Jul 15, 2009 | 07:30 PM
jude26's Avatar
Dang, 130???
My record down here in Miami is 113 degrees.
Old Jul 15, 2009 | 08:36 PM
Mustang5L5's Avatar
How low will the temp display read??
Highest i've had mine so far is 104 degrees
Lowest was 0 degrees. I was driving watching and hopingit would go to -1, but it never did
Old Jul 15, 2009 | 09:36 PM
Heist.'s Avatar
does anyone know the price of the sensor from the stealership?
Old Jul 16, 2009 | 01:26 AM
Tollboothwilley's Avatar
I'm in Phoenix AZ. Mine normally shows like 115, but thats cuz its really that hot.
If i'm parked sometime it will go up to 125 or so...but it only takes a min or two for it to settle to the real outside temp.
Old Jul 16, 2009 | 01:35 AM
ill Sedan
I'm guessing the proper name for this is the ambient temp sensor - $58.55
http://www.infinitipartsusa.com/part...layCatalogid=0
Old Jul 16, 2009 | 02:10 AM
Heist.'s Avatar
thanks!
Old Jul 16, 2009 | 10:54 AM
joedaddy1's Avatar
i had mine down to -8 or maybe -13 i believe... but it was negative.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
