How many quarts of fluid do I need to buy for 60k maintenence?
Old Jul 15, 2009 | 12:59 AM
mk3gtr's Avatar
I plan to buy the fluids online, but I'm not sure how many quarts I need of each. This is a 05 G35 auto. Do you guys know how much of each of these fluids do I need? I checked the manual, but doesn't really specify.
Differential oil
automatic transmission fluid
coolant (From the manual it seems like10 quarts are needed?)
My friend will also check the coil packs for the infamous oil leak, so I figure that I might change spark plugs as well. Are stock spark plugs the way to go?
thanks!
Old Jul 15, 2009 | 01:29 AM
04G35NYC's Avatar
The fluid for the Auto use Nissan J Matic fluid only.
Old Jul 15, 2009 | 07:04 AM
35bills's Avatar
Check at www.infinitihelp.com .....might be some info there for you.
Blue Dream's Avatar
I drove ttrank's car solo
Stock plugs are fine, but if you want to upgrade, check these out. Good price on them, might be cheaper than stock!
http://ngksparkplugs.ecrater.com/pro...hp?pid=2031849
Old Jul 15, 2009 | 07:51 AM
TurTLe*'s Avatar
5 qts for the ATF,
2qts for the rear diff
coolant is sold in gallons so 1 gallon should be more then enough for a drain and fill.
stock NGK are the way to go. copper are 20-30k, platinum are 60k. i personally run the copper since they are $2/each and its not that hard to change them, plus you keep a better eye on it.
Old Jul 15, 2009 | 08:09 AM
Swivel's Avatar
Moderator
Cooling system can take as many as 9 quarts if you can drain it completely, including the engine block. You can also use this for your AT.
More info:
CAPACITIES
Engine, with filter..........5.0 quarts
Cooling System, Initial Fill..........9.2 quarts
Automatic Transmission, RE5R05A Initial Fill..........Not Specified
Automatic Transmission, Total Fill
5 speed RE5R05A..........11.0 quarts
Manual Transmission, ..........6.1 pints
Differential, Rear..........3.0 pints
Old Jul 15, 2009 | 12:52 PM
mk3gtr's Avatar
More info:
CAPACITIES
Can you tell me where you got that info? TurTLe* posted 5 qts for the ATF, but your info does look more official
Old Jul 15, 2009 | 01:03 PM
Swivel's Avatar
Moderator
^^ My Amsoil web site. I'm a dealer.
Old Jul 15, 2009 | 01:17 PM
TurTLe*'s Avatar
I posted for DRAIN and FILLS. I should of made it clear. The guy posted specs on how much fluid is actually in the car. You will not get the get all the fluids out without a flush machine.
5qts of ATF and 2 qts of 75w90 is what you need for a drain and fill and thats more on the high side. I needed 4 1/4 ATF and 1 2/4 75w-90 mainly cause i spilled 1/4 trying to pump with on hand hold the bottle and hose in the other. There is 10qts of collant in the WHOLE engine system, in order to remove most of it you need to find all the freeze plugs on the block as well as remove the radaitor. I dont really do it, I just normally buy a gallon of coolant not mixed and make myself 2 gal, i let the radiator drain itself on the bottom and fill the radaitor cap untill i get bored and use up about 1.5qts.
also if you haven't get the pollen filter, take a very good look at the belts as most i've seens start showing cracks now. obviously oil change, and air filter. you mentioned plugs and coolant.
Old Jul 15, 2009 | 06:34 PM
mk3gtr's Avatar
Do you know if it matters if Genuine Nissan Synthetic Diff Fluid 75w140 or 75w90 is used? That's the only type http://www.thenismoshop.com carries. I see that the ATF is S Matic instead of J now...
Old Jul 15, 2009 | 10:20 PM
Swivel's Avatar
Moderator
True, thanks for clarifying for both of us. I would also suggest 75w90 for diff fluid.
miata007
Aug 17, 2015 04:36 PM
NemesisGee
Aug 11, 2015 07:10 PM
Frostbite91
Jul 27, 2015 05:25 AM
korfak
Jul 20, 2015 12:10 PM
