new noise sounds like supercharger whine
Old Jul 22, 2009 | 12:05 AM
JER's Avatar
JER
My 04 Sedan Auto with about 81k miles just started making this noise. It is 100% stock. No mods whatsoever. In 3rd, 4th, and 5th under about 30-60% throttle I started getting this whining sound. I only hear it around 2-4k rpms. I am worried it's the transmission. Anyone else have this noise?
Old Jul 22, 2009 | 07:01 PM
Tollboothwilley's Avatar
You sure that someone didnt install a SC overnight ?
Old Jul 22, 2009 | 07:36 PM
IPGSEDAN's Avatar
^^^ lol it was meeee!!!
Old Jul 22, 2009 | 08:26 PM
JER's Avatar
JER
yup.. anyone actually have any real ideas on what the noise might be?
Old Jul 22, 2009 | 09:17 PM
NjMatteSedan's Avatar
tell the car "stop whining!"
Old Jul 22, 2009 | 11:10 PM
JER's Avatar
JER
Does anyone on this forum actually have any useful information? I appreciate the attempts at humor but I am looking for some assistance on the problem.
Old Jul 23, 2009 | 12:18 AM
Nobody can diagnose a sound over the internetS
If you can explain it better...maybe get a video of it, then we might be able to figure something out.
You're expecting us to have an idea of what a "whine" sounds like to you. it could be the wheels,tires, brakes, axle, hub assembly, transmission, driveshaft, and several other possibilities.
Help us help you.
Old Jul 23, 2009 | 12:41 AM
JER's Avatar
JER
Well if it happens under 30-60% throttle between 2-4k rpms then we can probably rule out wheels, tires, axle, hub.. it's either intake, trans, or one of the accessories like p/s pump, water pump, alternator. I also said it sounds like a supercharger whine. That is a pretty standard sound. Mainly I am looking for someone else who has experianced this on their G and can point me towards what the problem was. I don't need anyone to guess or fill the board with jokes.
Help us help you.
Old Jul 23, 2009 | 12:53 AM
junbug's Avatar
Does it only happen when the A/C is on? A/C compressor?
Old Jul 23, 2009 | 12:56 AM
JER's Avatar
JER
A/C can be off or on. It makes the same noise either way.
Old Jul 23, 2009 | 12:59 AM
JER's Avatar
JER
I looked around on it tonight. P/S and Transmission fluid are clean and smell ok. Also everything on the intake looks good.
Old Jul 23, 2009 | 10:06 AM
junbug's Avatar
Did you get your belts replaced lately. An overtightened drive belt can do that. I was originally thinking A/C belt but if it happens all the time, could be the drive belt. Check the tension by trying to twist it. It should rotate between 45-90 degrees at the longest span if tension is within rage.
Old Jul 23, 2009 | 10:18 AM
JER's Avatar
JER
nope.. the only thing I have done recently is replaced the rear struts. the belts have been the way they are for many miles. i checked the tension and it is all good.
Old Jul 23, 2009 | 11:35 AM
SukaZenki's Avatar
It could be your Throw Out Bearing.
Old Jul 23, 2009 | 11:56 AM
JER's Avatar
JER
on an Automatic trans?
