Need fast reply help headlight baking
Old Jul 29, 2009 | 04:09 PM
toymachine2009's Avatar
I am in the process right now of painting my headlights right now. Just pulled down the front bumper got the headlights out. I heard this would make my oven smell really bad and not to do it in my home oven true or false?
preheat to 220 for 14 minutes
Old Jul 29, 2009 | 04:22 PM
G35Papa's Avatar
FALSE!
Put it on a cookie sheet.....220 for 14minutes on BAKE NOT BROIL
Old Jul 29, 2009 | 05:11 PM
Its pretty hard to pull apart after it has been baked should it be?
Old Jul 29, 2009 | 05:12 PM
scottsG's Avatar
its not gonna be super easy but its totally doable.
Old Jul 29, 2009 | 05:13 PM
g35freak86's Avatar
there are a couple screws you have to take out to pry it apart. take them out and then pull apart
Old Jul 29, 2009 | 05:14 PM
ok well i been trying to pull apart for 20 min now its not even warm so did the glue harden? Do i have to reheat it up by baking it again and try again?
Screws came out before it even went in the oven.
Old Jul 29, 2009 | 05:18 PM
g35freak86's Avatar
it takes some effort man. when your pulling it, do you see the sealent being stretched at all? Or is it not budging at all? Glue doesn't need to be hot, just warm
Old Jul 29, 2009 | 05:22 PM
Do I need two guys to do this. Cause this aint working. Ill try again. Im going to put it back in and warm it up cause its competely cool now and hard again. Ill try one more time
Old Jul 29, 2009 | 05:24 PM
g35freak86's Avatar
it can easily be done with one person. just heat it back up a bit
Old Jul 29, 2009 | 05:30 PM
ok thank you very much guys got it now time to paint
Old Jul 29, 2009 | 05:36 PM
we broke one of the bulbs in the orange part of the headlight do you know the part number or what kind of bulb it is?
Old Jul 29, 2009 | 05:40 PM
g35freak86's Avatar
If you're refering to the turn signal bulbs, they 7443
Old Jul 29, 2009 | 05:42 PM
ok thanks
Old Jul 29, 2009 | 05:47 PM
snotf's Avatar
do it with two people if you have a buddy available. wayyy easier. any longer than 5min out, the glue is re hardened. it's not going to be super easy. fwiw, those housings get SUPER hot with the bulbs normally, and have to be made to withstand a malfunction anyways, so 220 is nothing. i did mine @ 300 and was fine. i DID take ALL the bulbs out though and SOAK several rags in water and wrap the harness's up to prevent wires from getting melted though.
just my .02
Old Jul 29, 2009 | 05:50 PM
350GT-R's Avatar
shoot, i left all the wires in there, just took out the bulb, baked it and nothing happen, scary at first but cant wait to do something next to it. thinking about halos and projectors.
