Slight Knocking Noise at Throttle
Old Aug 4, 2009 | 08:49 AM
cubanato's Avatar
My 2005 G35x seems to runs beautifully. Except when I have the windows down and am next to a parked car or something that noise can bounce off from.
If I suddenly press the throttle hard not necessarily WOT but a good press Ill hear a knocking or clickity noise from what seems like the engine or front axle.
This noise only sounds for a second or 2
any ideas? could it be the regular Gas I put in it?
Thanks
Old Aug 4, 2009 | 09:12 AM
seung012's Avatar
You need to verfiy and make sure exactly where it is coming from. If it is a clicking or knocking noise from motor, sometimes it could be due to low oil... I say that because I had a motor that was consuming a lot of oil and at one point it was really low so once I put in more oil, it stopped the clicking sound.... if from suspension, number of things. VERIFY THE LOCATION.
Old Aug 5, 2009 | 02:20 PM
bkd's Avatar
bkd
It sounds like it could be pinging from lower octane fuel. How long has it been doing this?
Old Aug 5, 2009 | 02:38 PM
pwebb's Avatar
use 91 octane or better, and check your oil level.
Old Aug 5, 2009 | 02:57 PM
canucklehead's Avatar
it's engine pinging (knock) caused by the regular gas. use premium and you should be fine.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
dcsbh1
Oct 1, 2015 03:15 PM
