Few questions on lowering
Old Sep 2, 2009 | 10:43 PM
mcaron's Avatar
So i posted this in the suspestion forums and got no repy at all so i figured id give it a shot in here.
I've got an 04 X and im going to be buying a full set of 350z revised springs off a 2005 350z.
First off how much will these drop the F/R with my stock stuts? (i know there is no replacment for front)
Also will i need a front camber kit? (I believe anything lower than .4 inch's will need a rear camber kit)
Thanks everyone,
Mike
Old Sep 3, 2009 | 12:41 AM
4DGS's Avatar
On a RWD G it will drop the car roughly 1 inch all the way around (as said in the Look here before starting a new thread!! FAQ's) AWD models go down another .5" than RWD (also stated in said thread)
Therefore, Z springs will take your car down about 1.5" to see the results of that check out the suspension compilation thread.
With a 1.5" drop I don't think you will be needing a front camber kit, not sure where you heard the .4" thing.
Old Sep 3, 2009 | 05:18 AM
BuckeyeInMI's Avatar
Thanks everyone,
Mike
Dude, you've been here long enough to know you should search on this. There's 2 stickies on it for cripes sake.
https://g35driver.com/forums/brakes-...w-updates.html
https://g35driver.com/forums/g35-sed...uspension.html
Old Sep 3, 2009 | 07:21 AM
mcaron's Avatar
I've went thru all like 90 pages or so in the second link about 2 weeks back and with searching could neevr find the second one
Thanks so much tho
Old Sep 3, 2009 | 10:24 AM
mcaron's Avatar
Hmm i was liking the idea of only a 1 inch drop because it wouldnt be as much pressure on my stock struts (which is why i had earlier completly scratched the idea of lowering). 1.5 inch's is kind of pushing my limit here because this is my DD and because im AWD i cant put sport stuts up front(only in back)
Old Sep 3, 2009 | 10:26 AM
AARONHL's Avatar
No you will be good, the springs are not as stiff as you think.
Old Sep 3, 2009 | 10:32 AM
mcaron's Avatar
im scared about my struts
I've got 50k miles on my stock non-sport (X) stuts, how much longer you guys think they will last if i lower with revised 350's?
Old Sep 3, 2009 | 11:24 AM
ddpack's Avatar
Get the BC coilovers........
Old Sep 3, 2009 | 12:06 PM
mcaron's Avatar
i wish but 1000$ plus front an rear camber kits (525) is kind of alot for me right now.
Im getting these springs for 50$ pluz maybe a rear camber kit (120$) so i was thinking it would be kind of cheap
Old Sep 3, 2009 | 05:30 PM
FlyingLumpia's Avatar
if you get the coils and not lower it that much you dont have to worry about a camber hit.
I can always see my home made coilovers. VRT arm with front VRT coilover, koni rears and ebay coilover to someone for pretty cheap +shipping. The shipping will probably be pretty spending.
Old Sep 3, 2009 | 05:39 PM
AARONHL's Avatar
Could you post pictures of those home made coilovers?
Old Sep 3, 2009 | 05:48 PM
mcaron's Avatar
go to the lowered X thread, hes got pistures of everything in there
Old Sep 3, 2009 | 05:49 PM
mcaron's Avatar
btw, wouldnt work with your car, becuase theyve got the arm for the AWD models
Old Sep 3, 2009 | 06:16 PM
AARONHL's Avatar
Do you expect me to go through all 100 pages??????
Old Sep 3, 2009 | 06:18 PM
mcaron's Avatar
I did it so you can lol but they are made for AWD, i dont think they would work with your car. you can buy used coils in the marketplace for cheap anyways, i cant lol
