Loud A/C compressor '05 G35 Sedan
Old Jul 5, 2017 | 02:13 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just to rule out the obvious check tension on the AC drive belt. A LOT of odd sounds can be attributed to over-tension or under-tension on drive belts. Bearings can be damaged and create a whine sound if too tight or belts can develope a sort of "slack" spot if it's too loose (but still tight enough to not squeal) which makes a sort of "rattly and floppy" sound.
The video just sounds like damaged bearings though, commonly caused by over-tension on belts. They compressors still run for a super long time with damaged bearings though, typically the only thing that kills them is the constant dry-starting if the refrigerant has leaked out of the system.
Old Aug 15, 2024 | 08:37 PM
jonaevans's Avatar
G35 Sedan Base
Loud Sound
My sound is happening intermittently and happens at various RPMs. I turn the AC down and then up. The audible sound lessens when turning it down but stops when shut off. If I turn it back on, the sound is usually gone. It started about two months ago. I have about 98k miles. Any thoughts? I will try to compress the video to upload it.
champppy
Mar 31, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Rehman2009
Jul 27, 2015 03:23 AM
laksjd84
Jul 24, 2015 05:12 PM
