Code 445 Help
Old Sep 19, 2009 | 02:27 PM
irvgotti's Avatar
Code 445 Help
I got my service engine light on and i took it is to get checked... they said 445 evap code.. large leak...they guys told me its not a serious problem but its a problem... what is it and is it a warranty powertrain part??? infiniti is charging 110 to check it and if its warranty part they will wav fee. but i wanna make sure before i go to them..
Old Sep 19, 2009 | 03:28 PM
6MTFTW's Avatar
If you're handy with a multi-meter, you can follow the steps in the FSM to diagnose whether it's a wiring problem, or just a bad solenoid valve.
EC-352 is the page it starts on.
Old Sep 19, 2009 | 11:01 PM
BH818's Avatar
code 445 means PURG VOLUME CONT/V
Old Sep 19, 2009 | 11:05 PM
BH818's Avatar
check this out
it might be: "This valve operates on an on/off mode as it receives messages from the ECM. According to the engine requirements,
fuel vapor from the EVAP canister is released through this valve. The valve controls the rate of fuel flow. "
http://www.bba-reman.com/content.asp...ssan_dtc_po444
I know code as 444 its the same thing or similar
Old Aug 6, 2011 | 04:27 PM
irvgotti's Avatar
What now
So should i replace the solenoid?? . where can i buy it?
Old Aug 6, 2011 | 05:59 PM
BH818's Avatar
"It's a very common problem with Nissan vehicles. If the harness are not damage, it's very likely that the problem is the canister purge volume control solenoid valve"
http://engine-codes.com/p0445_nissan.html
check out any engine code on this site
engine-codes.com
I'll check where they sell the part
Old Aug 6, 2011 | 06:09 PM
BH818's Avatar
part # is 14935AM60B about $130 at the dealer in CA
$86.19 at infinitipartsusa.com
http://www.infinitipartsusa.com/part...gOEM&siteid=55
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
