255/35/19 all around?
Old Oct 3, 2009 | 03:02 PM
PAIXAO's Avatar
Picked up some coupe 19's 4-19x8.5 and am looking at tires now. Should I go 255/35 or 245/40? Need some opinions.
Dropped on z/g springs.
Old Oct 3, 2009 | 05:05 PM
Dark_'s Avatar
255 on the rear, 245 on the front (if you want it staggard).
You won't be able to rotate the wheels if you keep the tires the same size so either way.
Old Oct 3, 2009 | 06:18 PM
Bestswat's Avatar
did you buy these off PreacherMan at my350z?
Old Oct 3, 2009 | 06:24 PM
PAIXAO's Avatar
No, I've had these for a few months...
Old Oct 3, 2009 | 06:25 PM
PAIXAO's Avatar
Thanks Ryan, but they're not staggered wheels so why run a staggered set-up?
Old Oct 3, 2009 | 06:27 PM
Blue Dream's Avatar
I drove ttrank's car solo
Coupe 19's are 19x8 in front and 19x8.5 in the back.
I have 245/40's all around dropped on Tein H techs and when I replace the rears I'm going 255/40. The 255/40's are closer to the same diameter as the 245's than 255/35. The 35 series profile leaves too much wheel gap for me.
I'm also on coupe 19's.
Old Oct 3, 2009 | 06:40 PM
PAIXAO's Avatar
Yes... but I have 4 coupe rears...
Even the 245/40's are bigger in diameter than the OEM 215/55/17's. 255/40 will be even bigger than OEM.
Old Oct 3, 2009 | 07:58 PM
Blue Dream's Avatar
Ahh I see.....
Old Oct 3, 2009 | 08:12 PM
jimmyc13's Avatar
I'm running 245/40/19's for 4 years now and dropped on Z/coupe springs and love the look & ride...helps fill up the fenders a tad more w/ less of a gap.
Old Oct 3, 2009 | 08:53 PM
jekl1000's Avatar
I did! (Is that a bad thing?)
I was curious about this exact question, glad I stumbled on this thread. Does anyone have spacer recommendations to fit flush with the fenders when you have 8.5s on all 4 corners?
Old Oct 3, 2009 | 10:07 PM
PAIXAO's Avatar
No spacers needed. When I test fit mine they were flush.
Old Oct 3, 2009 | 10:15 PM
Dark_'s Avatar
Oh! I didn't catch the 4-rears part.
Well then it comes down to this:
Which will sit flush and not rub, if both then-
Which tire size is cheaper to purchase when comparing the same brand.
If you can fit 255's then I'd recommend 255's, worst case you may need a moderate fender rolling in the rear but I think you will enjoy the look of the wider tires (even though 245 and 255 is minimal).
Old Oct 3, 2009 | 10:30 PM
jekl1000's Avatar
Thanks again!
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
the93owner
19 Inch
Sep 23, 2015 03:03 PM
rjd350Z06
Archived Sales
Aug 9, 2007 12:12 AM
wantag
Dec 11, 2005 12:37 AM
