brake vibration?????
Old Oct 8, 2009 | 07:46 PM
Chief.Crappin.Squirrel's Avatar
i just rrecently installed brand new cross drilled and slotted rotors and hawk pads and i am feeling some vibration when i stop especially at high speeds .....but it isnt a vibration like when the pads are bad or the rotors are bad ... the only way i can explain it is that it feels like when a phone vibrates not pulsating but the car stops very well it just vibrates in the process let me know what you guys think?
Old Oct 8, 2009 | 08:05 PM
Mustang5L5's Avatar
Brand rotors? If they are cheapo e-bay type rotors.....well, you get what you pay for. A lot of guys experience this sometimes with certain brand aftermarket rotors. Unfortunately most cure it by getting another set of rotors.
Did you install new pads with the rotors? Did you do the bedding in process?
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Old Oct 8, 2009 | 09:45 PM
Blue Dream's Avatar
I drove ttrank's car solo
Thanks Mustang, I never knew this. Great information.
Old Oct 9, 2009 | 10:23 AM
yea i got them from rotor pros and if it keeps doin it im jus goin to buy a new pair and yea i did do the process but not as many times so idk mayb that messed me up but thaks for the info and other than like brembo and stop tech are there any other good brands out there thanks a bunnch guys
Old Oct 9, 2009 | 09:24 PM
Mustang5L5's Avatar
Rotor pros is actually half decent. I've used them before with sucess. Have you tried contacting them?
Old Oct 9, 2009 | 10:28 PM
gspot35's Avatar
It is possible to feel the pads contacting the slots.
If you don't bed your brakes and heat them all the way to gas the pads you've wasted your time (and gas).
Old Oct 9, 2009 | 10:44 PM
yea i think i will contact them but it doesnt affect the braking ability because it stops great it jus has that little vibration so idk
thanks
Old Oct 10, 2009 | 08:17 PM
Neu Era's Avatar
could be a manufacture defect? hes right about ebay though. dont trust 'em!
Old Oct 11, 2009 | 03:04 PM
Neu Era's Avatar
Sounds like your tires are off balance. Also do you have cupping on the inside of your tires? But then it'd be constant.
Old Oct 11, 2009 | 03:08 PM
350GT-R's Avatar
its not ur tires or brake pads.
i had the same problem.
it's probably that screw/clip for the drums for emergency brakes.
there's two of those clips. i found mine was rubbing behind my rotors and it makes it rattle alot. remove your rotors and get it checked out. probably u left ur emergency brakes on when removing the rotors and it got pulled out by accident.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
