Anyone running coupe S-techs on Z shocks and struts?
Old Oct 21, 2009 | 10:35 PM
4DGS's Avatar
This is one that isn't in the compilation.
Anyone running this set up? They will drop the sedan 1.7 and 1.4 Just under what the sedan S-techs will drop it.
How do you think this will look?
Old Oct 21, 2009 | 11:03 PM
bbs350z's Avatar
i have currently 06 z shocks on z s techs, drop is bomb. rear sits lower than the front, wish the front was a bit lower, but i can get a finger and a half in the front and just short a finger in the rear
Old Oct 21, 2009 | 11:14 PM
4DGS's Avatar
What size wheels and tires are you running?
Any camber?
Old Oct 21, 2009 | 11:26 PM
midnytegsedan's Avatar
since this thread kinda relates to exactly what i was thinking the coupe lowering springs will fit on my 03 sedan then?? the eibach sportline lowering kit...i only say cause i can get these at a nice discount through my job.
Old Oct 21, 2009 | 11:33 PM
NjMatteSedan's Avatar
yea they fit
Old Oct 21, 2009 | 11:42 PM
bbs350z's Avatar
Any camber?
factory camber on 245/40 r19 +40 rears (genesis coupe track wheels)
getting my new wheels/tires next week
245/40/r19 front 275/40 r19 rear +24 front +40 rear factory camber at the moment. drop is nice, but ill get pics up asap next week.
Old Oct 21, 2009 | 11:45 PM
4DGS's Avatar
Ok, that's pretty similar to what I plan on running. 275 might need some rolled fenders.
Old Oct 22, 2009 | 12:29 AM
04G35NYC's Avatar
I heard they are maaaad stiff harsh ride.
Old Oct 22, 2009 | 12:34 AM
bbs350z's Avatar
one step ahead of you sir!
not too bad, then again i was used to my z on jic flt-a2's...makes me wanna throwup my kidneys, so the g feels comfy. need to add sway bars though, rear feels a bit sloppy
Old Oct 22, 2009 | 12:35 AM
4DGS's Avatar
Where did you hear that? They are the same spring rates as the sedan S-techs, so I doubt they can be really bad??
Old Oct 26, 2009 | 11:48 AM
KevcoG35's Avatar
I run sportlines with 05 z struts/shocks. My car is low and it rides great! Good cheap alternative to expensive d-specs.
Old Oct 26, 2009 | 05:46 PM
bbs350z's Avatar
heres a pic of mine on my above listes setup (06 z shocks, z s techs)
Old Oct 26, 2009 | 11:13 PM
Tollboothwilley's Avatar
the shocks aren't really going to change the drop...
what was the total drop...about 1.5" right?
Old Oct 27, 2009 | 01:00 AM
4DGS's Avatar
1.7" in the front and 1.4" in the rear.
I think I'm just going to install the fronts to try and level it out.
Old Oct 31, 2009 | 04:25 PM
jimmykce1's Avatar
I like those wheels on your sedan bb350z. I am going to drop my sedan with Tein s-techs. Did you have to use toe bolts to pull the toe in? I m going to get OEM coupe 19's on mine.
rezendvous420
May 31, 2020 01:26 PM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
cyrus32
Jul 18, 2015 06:22 PM
