Need Help Regarding Spacer
Old Nov 20, 2009 | 03:44 AM
dilong's Avatar
Hi All,
I changed my 17" wheels to M sports 19" one. and I replaced my spring in couple's spring. drop a little bit and put 10mm spacer all around.
However, after 4 months installation. The front tires starting to rub the arm. I heard that I need 15mm spacer and maybe change my tire from 245/40/19 to 235/35/19. Can anyone give me some advice please? Is there a store close to Rosemead, California that is selling the 15mm spacer? Any recommend brand?
Thank you guys!!!
Old Nov 20, 2009 | 04:15 AM
reconJDM's Avatar
Ichiba and H&R is the only spacers company I can think of that I've used in the past with no problem.
call up your local performance shop and get a quote.
Old Nov 20, 2009 | 06:55 AM
4DGS's Avatar
There is a vendor on here that sells Ichiba, correct me if I am worn but I think it is M-motorsports
Look him up, they just finished a group buy I think so you missed out on that.
What has happened is you springs have finally settled in fully and the car has come down a little causing the wheel to rub. Unfortunate, but it happens.
Old Nov 20, 2009 | 01:55 PM
Tollboothwilley's Avatar
Hubcentric makes good wheel spacers as well.
I'm sure you can find a local place to sell them also.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
