Help with test pipe. Will this pass emission test??
Old Nov 20, 2009 | 10:47 PM
str3zz's Avatar
Question Help with test pipe. Will this pass emission test??
I look at this at ebay and yes I know is not a good brand but this is all I can afford right now.
Will this pass emission test? Anybody in AZ or some other state or might even have the same thing or have any clue about it please help me.
Spec and Features:
-100% SUS-304 Stainless Steel with computerized mandrel-bent
- CNC machine flanges for strong solid support
- TIG weld for strength and durability
- Increase 6-10 horse power and torque
- Straight thru design and bolt-on installation
- comes with gaskets and bolts
Inlet/ Outlet:
2.25" inlet, 2.5" outlet
These are cat-delete pipes, test pipes with built-in resonator. They are able to give a deeper sound, help to make the exhaust sounds better
Fit Models:
Nissan 350Z Fair Lady Z 02 - 07
Infiniti G35 03 - 07
Old Nov 20, 2009 | 10:50 PM
SDGenius's Avatar
won't pass
Old Nov 20, 2009 | 11:35 PM
tdruk's Avatar
emission test is total bull
Old Nov 20, 2009 | 11:57 PM
NFSP G35's Avatar
? = 2B || !2B
Guys on FBody.com used to run the car almost all the way out of gas then run it on denatured alcohol to pass emissions... IDK if you want to do that to your G though
Old Nov 21, 2009 | 01:55 AM
4DGS's Avatar
Buy berks HFCs, they pass E-test and they add the same power.
Don't buy something because it's all you can afford. Save up for the real deal or don't do it at all.
Old Nov 21, 2009 | 03:32 AM
str3zz's Avatar
Lol +1 I guess. I don't want anything permanent since I might going to trade in with newer g but just want to know what the different are since I already have hr y-pipe, coupe midpipe and hks rear just want the feel of it with test pipe but not the expensive type. On the other hand my registration expire in 3 month and I know it will require emission test but just don't want to remove it and put it back on.
Well thanks guys I guess I'm just gonna save the money for now
Old Nov 22, 2009 | 10:27 PM
pwebb's Avatar
a test pipe is simply a piece of pipe. there is no catalytic converter in it. you are basically removing your cats which is illegal, and will most definitely throw a check engine light which is automatic FAIL on any OBD II and up vehicle.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
