Any Idea?
Old Dec 4, 2009 | 12:54 AM
Infiniti25G's Avatar
Any Idea?
Ok So I finally get to drive my car after being deployed for the last year. I checked all pre driver after you have been gone, Things Oil/Radi/Break fluid etc. I checked the air in my New Tires 33 psi all around... Now here is my problem.
When I get to the speeds of 50-90 If I turn the wheel to the left it shakes a little in the steering wheel.Like something rubbing but its only when Im at high speeds and turning to the left.I thought it was the breaks but.
I went and got my Rotors Replaced with New Pads and It still does it...Any Idea?Also It just seems to be the front left.
Old Dec 4, 2009 | 02:09 AM
bbs350z's Avatar
sounds like wheel bearing maybe
Old Dec 4, 2009 | 03:02 AM
G35Papa's Avatar
Wheel bearings will also typically make a humming noise when they start getting bad. Jack the car up on the one side you think is bad and grab a hold of the wheel, see if it wiggles. It shouldn't but if the bearings are worn enough, it will feel loose/sloppy.
Also, have you had an alignment done on your car? Has it just been sitting on a concrete surface for the full year or was it driven at all?
Old Dec 4, 2009 | 08:47 AM
Mustang5L5's Avatar
Did you torque the wheels correctly?
Old Dec 4, 2009 | 08:02 PM
I took a Look at it when they were putting my New Exhaust on Today ..Kinetix High Flows with MR Y Pipe 06 mid and HKS..It seems to be the bearing...The guy qouted me 475 with parts...For the Bearing Hub and assembly...Is it tough to do bearings?
Old Dec 4, 2009 | 08:19 PM
kayveeee's Avatar
i need new wheel bearing too, my car sounds like a damn airplane -_-, but don't our car just need a wheel bearing thats only like $70 and not the hub as well?
Old Dec 4, 2009 | 08:27 PM
bkd's Avatar
bkd
It's not much harder than changing the brakes and rotors if you buy the assembly. Parts are about $150 IIRC. I doubt it would take more than 20 minutes with air tools. I would never pay someone $300 in labor to do this on my car. On the other hand, I would charge a lot more than that if I had to do it for someone else. :^)
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
hrdwirk1
Oct 2, 2015 06:34 PM
wow600rr
Sep 28, 2015 11:50 AM
Jcruzg35
Sep 26, 2015 04:47 PM
