Installed MREV2 today :)
Old Aug 3, 2011 | 12:41 PM
ResoG35Sedan's Avatar
Originally Posted by G. Dizzle #2
my oem looks like a mrev2... could you perhaps have mixed up the pics? i have a 2003 6mt... or could they have installed a mrev2 on my car from the factory? see pic. i also noticed the mrev2 pictured above has the letters M L1 & M R1 on it, mine has M L2, & M R2 on it, what does that mean?
Attachment 141551
Yes, you have a Mrev2 (kinda) factory installed on your car ...... your stock lower manifold is the same as the Mrev2 manifold, except the Mrev2 has been polished and stuff for better air flow .....
Just like 'High_Boost' said, we with the 'RevUp' engines (2005-2006 6MT G35's only) have the crappy lower manifold. In order for us to get benefits from Plenum Spacers we need to change our lower manifold as well, either to Mrev2 or non-RevUp OEM manifold.
and I have no idea what those 'markings' mean, I'm guessing its 'versions' or something
Old Aug 3, 2011 | 02:22 PM
G. Dizzle #2's Avatar
Originally Posted by High_Boost
yours is the same stock.. the mrev 2 is an 03-04 manifold that is ported
they changed it on 6mt 05-06 "rev up" motors
oh! well good for that, one less thing i have to buy... saving $ FTW (well actually i'll use that $ for something else... back to square 1 = BROKE! ha!)
Old Oct 14, 2011 | 05:48 PM
I just installed my 'self-made' Mrev2 ........ I'm very happy with the results, they are more than I expected ....
Now I'm thinking of putting a "Motordyne 5/16" spacer, but for a little bit more money I can buy the "Kinetix Racing V+" intake plenum ...... I did research and found that:
1. Motordyne spacer = 10-14hp
2. Kinetix Racing V+ plenum = 14rwhp
Has anyone had any experience with the two, separate or together?
btw, this is on for 'RevUp' motor ( 2005 G35 6MT Sedan )
Old Oct 14, 2011 | 08:15 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Check out Motordyne's website, they had a plenum shoot-out in which they out performed almost every plenum setup back then. IIRC, the only one that beat them was the Cosworth, not sure on that. The spacer gives a more consistent power curve, where as the V+ gives better peak. Do some research on the subject and you will most likely buy the Motordyne spacer.
Old Oct 14, 2011 | 10:34 PM
BAUSauto's Avatar
Sickkk
Old Oct 17, 2011 | 11:52 AM
Yea, I'm going with the motordyne spacer, thanks for pointing out that motordyne have done the test and comparisons
Old Oct 17, 2011 | 12:30 PM
slim17265's Avatar
thank you so much for the pics..what I see is that on Mrev2 the entry area is smaller and the top of casting possibly indicated that the port has a small diameter and LONGER passage which will enhance velocity....as a worker, racer of small block Chev and big block ford it is necessary to be careful as sometime too much is just that too much....smaller rough passages depending on cubic insize of motor can most times create enough velocity to keep the fuel droplets small and atomized when it hits the heat of the passage itself. On motors that that run cool and have large intake passages the fuel will not stay atomized and the droplets will fall to the floor of the passage puddling up and causing eratic power at low speeds...on a small motor that we are dealing with sometimes a very small change big or little can be disasteres.
the fact that you noticed power above 4500 tells me that the engine is breathing better with the enhanced velocity...I will have to check to see if they fit an 03 or if there is something out there as aftermarket that will work...my car runs extremely well for only 214 cubic inches with tremendous torgue for the size of it..
Old Oct 17, 2011 | 01:18 PM
Hydrazine's Avatar
Hi Guys,
Here is an independent test of the MREV2 on a non-revup engine where the stock and MREV2 are compared.
http://my350z.com/forum/intake-exhau...5-touring.html
GABE3D independent test comparison of MREV2 Vs Cosworth
http://my350z.com/forum/intake-exhau...motordyne.html
Cosworth Vs MREV2 comparison
https://g35driver.com/forums/intake-...lled-pics.html
http://my350z.com/forum/na-builds/44...-revup-17.html
jsimonk
Dec 22, 2023 03:49 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
itztwinki3
Oct 5, 2015 11:29 AM
Jussaku
Aug 4, 2015 12:45 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
