Is it a must to roll fenders for coupe offset?
Old Dec 10, 2009 | 05:31 PM
TuckedG35's Avatar
I might be selling my wheels which are 30mm offset front and 40mm rear(i have a sedan obviously)...i was thinking about getting the coupe offsets.which are 15 front and 20 rear.wheels are 19"....would it be worth it? do i have to roll my quarters? and if so...who can do it??!?! help me!
Old Dec 10, 2009 | 05:46 PM
OCG35's Avatar
you're gonna need to do more than roll fenders... depending on the width, you'll need to flare them - and/or run massive negative camber.
Old Dec 10, 2009 | 05:52 PM
ShanesG's Avatar
Whats the width of the wheels???
Thats not TOO aggressive you can fit with a nice roll and a lil stretch and or camber. You will 100% need a roll. Where are you located??
Old Dec 10, 2009 | 08:55 PM
TuckedG35's Avatar
i am from North NJ,iam prolly jus gunna get tha sedan offsets,i jus thought it would be cool to rock coupe offsets,o and they are 19x8.5 front and 19x9.5 rear
Old Dec 10, 2009 | 09:00 PM
CandlestickPark's Avatar
ill Sedan
Those widths and offsets are totally doable. With the right drop so the tire is right at the fender, a very flat roll in the rear, the correct tire size (nothing larger than 255/35 in the rear without a fender pull or running a mad amount of neg camber) and enough negative camber (~-2.75 to -3) they will sit very nicely.
19 x 8.5 +15 / 19 x 9.5 +20
245/35, 255/35
More pics here: https://g35driver.com/forums/media-s...tin-flush.html
Old Dec 10, 2009 | 10:13 PM
DR NISSAN's Avatar
It's not a must but your G will look sexier if you do
Old Dec 10, 2009 | 10:33 PM
4drmadness's Avatar
roll and pull a lil for those offsets if its a 10.5 rear. what is the width?
Old Dec 10, 2009 | 10:37 PM
ill Sedan
Widths are 8.5/9.5
Old Dec 10, 2009 | 10:41 PM
4drmadness's Avatar
^ fail on reading. thanks! aggressive roll shud be good then.
Old Dec 10, 2009 | 10:48 PM
ill Sedan
^haha no worries Vivek.
Old Dec 11, 2009 | 05:03 AM
NAT@FFTec's Avatar
like marcus(candlestickpark) and everyone else said, as long as you are running about 3 degrees of camber and have your fenders rolled, you are in the clear for a 9.5+2x in the rear and 8.5+2x in the front. you wont need to pull your fenders
as far as looking for someone that can roll fenders, you might have some luck posting in your regional section. you can also buy your own fender roller for 250 and charge people once you know what youre doing
btw what wheels are you looking at OP?
Old Dec 11, 2009 | 05:49 AM
iiiiiekoiiiii's Avatar
you're in jersey... Check out g35nyc.com a member on there rolled my fenders in brooklyn...
His user name there is FELIX... My fenders came out cleannnn, no paint cracking, we did it mid summer with heat gun...
Kinda cold out now 25degrees at the moment. but indoors and heater gun will work...
Im runnin 19x9.5 35offset with 275/35 kinda meaty... But I can't put a key between the tire and fender...
Brodys_GCoupe
Nov 7, 2015 08:06 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Popes
Jul 29, 2015 05:07 PM
Soumilg
Jul 18, 2015 12:33 PM
