I am soo sorry to do this...
Old Dec 16, 2009 | 03:34 PM
UNH1569's Avatar
Hey Guys,
Soo sorry to start a new thread on something that has likely been answered somewhere else, but I'm a newb and I have been reading through threads for hours and have not come up with an answer yet...
I have an 04 G35 Sedan 6mt, totally stock. Wondering if the G37 10-spoke 19" coupe wheels and stock tires will fit on my car, and what size spacers I would need to make it look good. (Any other suggestions for making this work would help too...I love those wheels!) Thanks in advance for any help/input. These threads are totally amazing and so helpful. Also, I would love to see some pics if anyone has done this combo!
Old Dec 16, 2009 | 03:36 PM
PAIXAO's Avatar
Yes, they fit and I don't believe you need spacers.
Old Dec 16, 2009 | 03:51 PM
ttrank's Avatar
Grocery getter
I just saw one the other day here in AZ with that setup. They look great without spacers.
Old Dec 16, 2009 | 04:03 PM
OCG35's Avatar
OP - your post is so endearing, makes me want to hug you
Anyway... I copied this from another forum (this forum wont allow link, it changes the address)
G37 OEM Wheels Specs
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
G37
non sport
Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:
Front width: 8.5" +30-35mm offset
Rear width: 9.5" +30-35mm offset
*NOTE: G37 and G35 coupe offests differ completely. G35 coupe offests are way to aggressive for the G37 and will not work*
1st GEN G35 Sedan OEM Wheel Specs
Sport Model (2003-2004) & Non Sport Model
Front & Rear: 17x7 +45mm offset
Weight: 23.2lbs
Sport Model (2005-2006)
Front & Rear: 18x7.5 +45mm offset
Non Sport Model (2005-2006)
Front & Rear : 17x7 +45mm offset
All first Gen years
Front width: 8.5" +29-30mm offset
Rear width: 9.5" +35-40mm offset
Rear width: 10" +42-45mm offset
245 series front tire and 265-275 rear tire are most commonly used
so they should fit - definitely will not need spacers... might need to run a bit of negative camber
Old Dec 16, 2009 | 04:06 PM
bluemax189's Avatar
Awesome find ^^^
Old Dec 16, 2009 | 04:09 PM
Dranom's Avatar
great find mike!
yeah OP you wont have any problems rockin 37 wheels
will def look great
Old Dec 16, 2009 | 04:13 PM
Jeff92se's Avatar
Red Card Crew
53.5 lbs and 57.5 lbs Wow what a winning combo.
But if you're still interested in adding 8-12 lbs per wheel, Da Mayor did it awhile ago:
https://g35driver.com/forums/media-s...gen-sedan.html
Old Dec 16, 2009 | 08:18 PM
UNH1569's Avatar
Awesome!...thanks for the help guys. I'll post a couple pics when I pick them up!
Old Dec 16, 2009 | 08:29 PM
Swivel's Avatar
Moderator
If you don't drop it at the same time, you're gonna look like a 4x4 until you do...
Old Dec 16, 2009 | 08:46 PM
labguy94's Avatar
G37 wheels look great! Here's a progression thread by a member with the G37 wheels. (03/04 with Nismo).
https://g35driver.com/forums/g35-sed...-progress.html
Old Dec 16, 2009 | 10:11 PM
UNH1569's Avatar
Thank you so much for adding that thread!...That guy is doing pretty much everything that I want to do to my 04 sedan. Great to see how everything came together! Looks awesome
Old Dec 16, 2009 | 10:34 PM
j 4 lD's Avatar
Make sure to lower your car at the same time you get wheels (or before), or else you will look something like this:
Old Dec 16, 2009 | 10:48 PM
NjMatteSedan's Avatar
haha the title of this thread sounds like you're breaking up with your Girl or something
Old Dec 16, 2009 | 10:52 PM
OCG35's Avatar
seems sincere though... and at least he (or she) tried researching before posting... G37 wheels on a 35 isnt entirely unheard of, but its not super common like z to g or coupe to sedan.... so I think his humble demeanor and attempt to search is what had most of us helping rather than search bash him
Old Dec 16, 2009 | 11:04 PM
^ i know haha i picture him searching like crazy and not finding ishh and he's like oh mann i'm soo sorry to do this
