trunk swap question
trunk swap question
I have an 03 G sedan with the doggy door trunk. How difficult is it to swap out the trunk lid with on from a non doggy trunk lid? any different wiring things or anything? thanks alot
^I havn't done it yet, but from what I understand, you'll have to wire the trunk release button somewhere else (such as by your VDC button) or do away with it and use your remote. This question has actually come up quite recently.
Here you go. I found the thread I was looking for.
https://g35driver.com/forums/g35-sed...sedan-lid.html
Just use the keyfob to open the trunk. As posted in the other thread, you can buy a switch for an 04 and wire it up. I did that but I wired it to the trunk release power button in the glove compartment. Other than that, just remove the wiring harness and emergency pull cables from your existing lid and run them through an 03.5 on up lid.
Good luck
Good luck
Oh...if you are interested in the trunk release switch....go here...but give them a call to make sure you are getting the right part. On a quick search, I came across a SWITCH ASSY-TRUNK OP for an 04-07 but I'm not sure if that is the part we are talking about or not.
https://www.infinitipartsonline.com/...dan-parts.html
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
