taillight tints
#92
What everyone seems to be forgetting is the reflector requirements. You have to have reflectors on the back of your car. Ours are integrated into the center of our stop lamps. Other cars that have clear tails have them on the bumper (look at the lexus RX posted earlier). This is another reason I wanted to paint the inside housings vs. tinting them or painting the lenses. The bluebat GTR's are the best option if you want to fight a ticket.
#93
Good point though...
#94
damn it Eddie, I wanted go go home (still at work) - but it bugged me so I had to find my notes - there's more to it, but here's the relevant...
24607. Every vehicle subject to registration under this code shall at all times be equipped with red reflectors mounted on the rear as follows:
(a) Every vehicle shall be equipped with at least one reflector so maintained as to be plainly visible at night from all distances within 350 to 100 feet from the vehicle when directly in front of the lawful upper headlamp beams.
so yes, you are right - it is from directly behind (I believe I was thinking about rear side markers (which yes, they are required and we have)
(f) Area reflectorizing material may be used in lieu of the reflectors required or permitted in subdivisions (a), (b), (c), (d), and (e), provided each installation is of sufficient size to meet the photometric requirement for those reflectors.
^^^this makes it easy to "Fix" if it doesn't currently reflect
24610. A reflector placed on vehicles under Section 24609 which is of the button or other multiple-unit type shall contain not less than seven units with a total of not less than three square inches of reflecting surface. The red reflectors required may be separate units or a part of the red taillamps, but in either event the reflector and taillamps shall comply with all of the requirements of Sections 24600, 24602, and 24609, and any reflector constituting an integral part of a taillamp shall comply with all photometric requirements applicable to a separate reflector.
Happy tinting
Happy tinting
#96
wait a minute, I almost forgot... regarding the "Reflector" requirement - this pic shows the rear reflector simply from the flash on my point & shoot camera... actual headlights (the way it is required in the vehicle code) would reflect even more... just the flash reflects them almost as much as the leds illuminate ~
So no problem with reflectors however, this is my previous smoked (a little lighter than current) - I should look to see how much they reflect now...
for those that don't know, the reflectors are the three lines just inside the rows of led dots
#97
That looks to be a pretty weak flash
I was planning on taking a picture with a car behind my car with it's lights on. I'll utilize my wifes car which has very weak head lights. I've even installed better bulbs and it doesn't matter. The reflectors in her headlamp just suck. Anyway that is off subject
#98
I see the side reflector now on the rear.
Here is a picture of that JDM sedan with a coupe front end. As you can see the reflector on the side is all lit up. Luckily I painted behind it so it should still work as intended. (although I did want to paint it )
Edit: off the subject, does anyone know where I can get those red lip strips? I know where this guys shop is so I can ask him, but it can be so difficult trying to talk to these guys in Japanese.
#100
#101
The JDM tails still have that reflector but don't have a LED in it. I'll post some pics later if you want to see the JDM's.
There is a rubber strip that you can buy. That is what I want.
Last edited by psedog; 01-14-2010 at 01:07 AM. Reason: Wanted to add a reply to nfsp :)
#104
Yep those wheels. I wanted to see if they had black to kind of match the black paint on the wheels. Plus I want a little protection. I plan on getting some Akebonos and I'm going to paint the calipers. Figured I could go with a colored strip then to match the calipers and see how it looks. Right now a color would look bad since I currently have a monochrome look
