350Z suspension, replace A arm?
Old Jan 13, 2010 | 06:31 PM
jotsuka's Avatar
Hey guys I am replacing my suspension tonight with 350z shocks/springs the whole lot... well with the kit was the A- arm...
1. Should I replace this as well?
2. How hard is it to replace?
P.s. I know how to use the search function.... but maybe I am using the wrong terminology
Any thoughts would be appreciated, thank you
Old Jan 13, 2010 | 07:14 PM
canucklehead's Avatar
the search would maybe work better in the TECH section, suspension forum.
when i did the Z suspension swap there was no need to replace anything but the shocks & springs. i did buy new nuts & washers where indicated by the OEM service manual. not sure where you got this "kit" since most guys just pick up a 2nd hand set from a Z owner.
Old Jan 14, 2010 | 12:10 AM
4D05G35's Avatar
I just put Z suspension on my sedan yesterday. The guy offered the A-arms as well but I declined. I searched it out on here as well and found nothing. The drop is nice (im running 235/35/19's) shortens the gap, but camber change is minimal. IMO you dont need camber adjustment...
Old Jan 14, 2010 | 07:01 PM
jotsuka's Avatar
ok great thank you very much for the exp info !!
rezendvous420
May 31, 2020 01:26 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
cyrus32
Jul 18, 2015 06:22 PM
