Purchasing a G35x with 77,000 miles...need advice
Old Feb 5, 2010 | 02:25 PM
Gnightsedan's Avatar
wear and tear stuff can get expensive, if u burn through tires the way i do. Otherwise my car is a reliable nissan
Old Feb 5, 2010 | 07:24 PM
BuckeyeInMI's Avatar
Originally Posted by cfloson
As far as servicing the transmission... is that something that only needs to be done at 100k?
Nope, should be done every 60K. Since it's an AWD, you'll want to do the front and rear differentials every 30K, and the transmission and transfer case every 60K. FSM says it only needs to be inspected, but fluid replacement is better.
Transmission: Nissan Matic S (don't use anything else)
Transfer Case: Nissan Matic D (don't use anything else)
Differentials: 75W-90 or 80W-90 Gear oil, preferable synthetic. Many use Amsoil Gear Oil (80W-90) or Amsoil Severe Gear Oil (75W-90).
Old Feb 8, 2010 | 03:32 PM
cfloson's Avatar
I love this car. Absolutely solid and its a beast in the snow. Thanks for the words guys.
"Since it's an AWD, you'll want to do the front and rear differentials every 30K, and the transmission and transfer case every 60K. FSM says it only needs to be inspected, but fluid replacement is better."
Two questions:
How much should that run me to get it done by a mechanic?
Should i only bring my car to an infinity dealership to get it fixed (ripped off'd)?
sorry for the noob questions.
Thanks
Clayton
Old Feb 8, 2010 | 03:56 PM
blazeplacid's Avatar
you can do the differentials yourself
make sure you take the filler plug out first
then take out drain plug.
re insert drain plug, use a pump to insert new fluid in the fill plug.
re insert plug
the differential fluid is pretty cheap
if you dont have the tools to do it, a shop shouldn't charge much to do it
Old Feb 9, 2010 | 12:54 AM
Don't know about the cost, but you don't need to go to Infiniti to have it serviced. If you don't want to do it yourself, get a quote from someone to just do the labor and you buy/supply the fluids so you know they're using the correct stuff and there isn't any markup on them. I was going to have a local place do my last oil change because I didn't feel like crawling under my car in mid-winter, and they said $20 if I brought in my own oil (which I'd already purchased). We got a warm spell (38-ish) so I just did it myself.
Old Feb 9, 2010 | 12:56 AM
infinity dealership
Old Feb 9, 2010 | 11:37 PM
jayflyxx's Avatar
my 05 G35x is at 106k! No problems and i've owned it since 38k.. just oil changes, 1 set of 4 tires and pads... compared to my friends 07 3 series with abs light, check engine light and a bad thermostat!!!
Old Feb 10, 2010 | 12:19 AM
You haven't replaced the transmission or differential fluids? Or your engine coolant? Yikes!! (Note to self, do not buy any used cars from jayflyxx).
The engine coolant should be replaced every 60K per the maintenance schedule. And while that schedule also says that the tranny/diff/transfer case only needs to be inspected every 30K, it's pretty foolish to go over 100K without any replacement. You may be running fine now, but you've probably shortened the life of your transmission by a significant amount. Many people here change the diff fluid every 30K and the transmission every 60K. I plan on keeping my car for many years, so that's the schedule I'm going to maintain.
Hope your car is paid off, because when that transmission goes, it's gonna be a costly repair.
Old Feb 10, 2010 | 12:37 AM
jayflyxx's Avatar
my car gets serviced by Infiniti per the owners manual schedule. I am only 1,000 miles over on my big maintenance which will be done in March. My G now is sitting until then unless it snows as I use my 97 Accord. Everything is changed and has been changed as it should be.
Old Feb 10, 2010 | 01:28 AM
OK, I retract my buying statement. Just a little concerned because of some people I've known who never changed certain fluids and then wondered why their transmission was gone at about your mileage. Good to hear you're not like that.
Jiggerjuice
Oct 5, 2015 02:33 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
miata007
Aug 17, 2015 04:36 PM
Mac8008
Aug 4, 2015 09:19 PM
nascarbuff17
Jul 16, 2015 10:23 AM
