Side Marker Blinker mod
Old Sep 7, 2004 | 08:01 AM
SixFive's Avatar
Re: Side Marker Blinker mod
Also the passenger side wire to keep normal and blinking light is green on my car on both side not purple on the passenger as some directions had it. I wonder if there are supposed to be a couple colors they can use for different wiring?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Sep 7, 2004 | 02:14 PM
townsley's Avatar
I thought that the green wire with yellow stripe was the target. However, I was unable to find the coresponding purple wire on the other side. Closer inspection revealed a green wire with a white stripe located in a bundle higher up and deeper into the well. In this case, I did find a coresponding purple wire on the passengar side.
I did this mod just last weekend - worked like a champ! Clear corners are on the way too!!
-townsley-
03 Premium BS/Willow 5ATS
ZTube/K&N Drop-in/Sport Suspension
Grounded/Tinted/Splash Guards
Lip spoiler/Aluminum Pedals
Old Sep 7, 2004 | 05:06 PM
SixFive's Avatar
hmmm - I wonder what blinking clears look like - I guess that's US spec right. I think my 01.5 passat had clears with a yellow bulb..dont bimmers have yellow lenses with a white bulb.
Is there a DOT requirement for blinking side lights or anything to be concerned about? If a cop stops me for these lights i'd probably get in a lot of trouble with my reaction. Although my ticket to pullover ratio has dropped to about 30% as I show respect and dont make excuses, that would make me lose it.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Sep 7, 2004 | 06:12 PM
Streaker's Avatar
Tnx for the info. Has anyone actually layed out the procedure? I.E. what wires go where and any other helpful stuff. It's a mod that I definitely will do.
Streaker in GA
Old Sep 7, 2004 | 10:29 PM
fnt's Avatar
fnt
Streaker:
There definitely are good descriptions around - try a search on blinker mod (or something similar) here and on freshalloy.com, and you should find what you want.
Old Sep 7, 2004 | 11:11 PM
nate's Avatar
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
http://www.6mt.net/shop/sidemarker.asp
https://g35driver.com/forums/showfla...t=1#Post151504
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages. See my profile for updated mods list and pics.
Old Sep 10, 2004 | 07:42 PM
Silver03G35's Avatar
can someone help me on this, ive looked at all the pictures and read all the directions. but i need to know when you cut the black wire what do you do with the other end of the wire, the part that you dont use. just leave it hanging there??????
Old Sep 10, 2004 | 08:04 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
tape it up with electrical tape
Golden Gate G35 Club
jsimonk
Dec 22, 2023 03:49 PM
khamlin
Aug 2, 2015 09:37 PM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
