New G35 Owner, need advice
Old Feb 15, 2010 | 12:14 AM
  #61
BuckeyeInMI's Avatar
Originally Posted by morepowerjoe
I got my 06 front brakes installed today. It feels a lot better. The touchiness and squeaking is gone. I just used the old pads from the donor for now, but they were in really good shape. This is a great cheap upgrade.
I'm prepping my 06 setup right now. One of the rear calipers had a tiny hole in the piston boot, and both front calipers have been sitting in someone's garage for several years, and the boots are very dried out and cracking, so I'm just going to rebuild all 4 calipers. But while I've got them apart I'm going to paint them. Nothing fancy since they're just OEM, so probably silver or black. Also going to paint the rotors so they don't show any rust. I'll use the old pads to remove any paint I get on the contact area, then install some new ones.
Old Feb 15, 2010 | 08:09 AM
  #62
morepowerjoe's Avatar
Cool. Let me know what you think when you get yours done.
Old Feb 17, 2010 | 08:42 PM
  #63
I have a steering wheel shake between 60-80mph. It did it with the stock wheels and tires also. It's not to bad. When I take my hands off the wheel I can see the steering wheel bounce back and forth (left to right) real fast. When I put my hands back on the wheel it stops. Anyone know what it is?
Old Feb 22, 2010 | 10:10 AM
  #64
bump
I got the 06 rear brake swap done. Kinda sucked because alls I needed was the caliper brakets (calipers are the same), but I had to buy the calipers, and rotors from Nissan Unlimited. They wouldn't break up the set. And one of the rotors was bad anyway and I ended up buying the rotors new. So total cost of the rear swap was $275 with the salvage yard stuff and new rotors. I got the Hawk HPS pads coming for the front and rear.
Old Mar 12, 2010 | 08:22 AM
  #65
I first got the front hawk pads on and I loved them. It was definetly more of a progressive feel. It got rid of the touchyness I didn't like. About a week later I did the rear with the hawk pads and it kinda tightened back up. It's still way better to me, but I kinda wish I would of left the oem pads in the rear I just liked that balance better. All in all, a great upgrade.
Anyone know what I should look for on my steering wheel shake? I'm thinking tie rods, but can't find any play in the outers and can't really see the inners with that boot on. What about the rack n pinion? Could it be wore out? I don't know may be I should just have my wheels rebalanced first and go from there.
Old Mar 12, 2010 | 03:14 PM
  #66
Skyfox16's Avatar
Did you do the front swap with the brakes yet? I am looking to do the front and rear upgrade and found calipers but wasn't sure if u needed to change the brakets ? If so does anyone know where you can get just the brakets?
Old Mar 12, 2010 | 04:52 PM
  #67
Yes you have to have the brackets, and rotors of course. That's why I went to the salvage yard, unless you wanna go to the dealer
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
Chattzx
Jul 17, 2015 11:23 AM
